paul v6
posted on 19/10/05 at 05:55 PM |
Renault 5 Turbo
I have been offered a mint 190bhp R5 turbo engine with all ancilaries for a very very reasonable price, but you guessed it!!
What gearbox to use???????
I've read through the archives and found little to help so I'm hoping somebody has found a solution recently.
There has to be an option thats not too much hard work!!
Paul
Danozeman
posted on 19/10/05 at 06:24 PM |
Them engines can give trouble.
Best bet is probably to get a bell housing made up for a type 9.
Dan
paul v6
posted on 19/10/05 at 06:46 PM |
I know they must be like rocking horse poop but what about a Renault Fuego box??
paul v6
posted on 19/10/05 at 07:05 PM |
Or a RWD volvo box thats not a rear mounted type??
There must be a way around this??
owelly
posted on 19/10/05 at 07:18 PM |
rear mount it complete with gearbox. Or is that too obvious
http://www.ppcmag.co.uk
gazza285
posted on 19/10/05 at 07:20 PM |
Alright, apart from being a transaxle design.
andybod
posted on 19/10/05 at 07:39 PM |
some early renault traffics are rwd or how about dacia duster but not sure if transfer box was seperate from the gear box or remove bell housing from
volvo 340 and see if it could be adapted to fit type 9 box
Volvorsport
posted on 20/10/05 at 10:14 AM |
wouldnt a type 9 , be a little fragile on such a motor ?
bellhousing from a 340 could possibly work , but they have a tailshaft housing bolted on, so they can be quite small in that area , its obvious to me
to bang on a transaxle and stick it in the back !!
otherwise , id be picking a more reliable motor , altho i do have stocks of pistons and liners !!
www.dbsmotorsport.co.uk
getting dirty under a bus
caber
posted on 20/10/05 at 07:00 PM |
Dacia Duster? Is this not a Renault 12 clone? If so I think it is front wheel drive with the engine in line behind transaxle. Renault 16 engine and
transaxle were the same period as the original 12 and these were the original power transmission unit for the Lotus Europa.
Caber
