paul v6
posted on 20/10/05 at 07:59 PM |
Chassis Analysis?
I'm in the middle of building my chassis which has a few changes to the standard book chassis, using different sized material and incorperating
a number of additional triangultions. It would be good to run these changes through some software but I have no idea what to use or where to get
it!
Any ideas???
Many thanks
Paul
CommanderAce
posted on 20/10/05 at 08:13 PM |
SolidWorks, erm, your brother!
paul v6
posted on 20/10/05 at 08:18 PM |
You told me yesterday that you didnt have software to analise a chassis.
If you do then get on with it!
CommanderAce
posted on 20/10/05 at 08:19 PM |
Times change and I have a degree course to do, so no!
miserableoldgit
posted on 20/10/05 at 10:23 PM |
If it's any consolation I have a sibling like that.
Must be in the jeans.
Youth and vitality are wasted on the young
NS Dev
posted on 20/10/05 at 10:43 PM |
sod the software!
If it looks right it'll be fine, if it doesn't then it won't!
really technical coming from an engineer but the chassis is hardly the epitome of engineering excellence to start with so I wouldn't worry too
much!!
Aboardman
posted on 21/10/05 at 06:39 AM |
where would i get a trial version of solidworks, would like to try.
Can use autocad very good and do 3d models in it, is it a lot harder to use.
Andrew
James
posted on 21/10/05 at 09:00 AM |
Paul V6,
Just do the Cymtriks mods.
It's all done for you then!
James
- Muhammad Ali
paul v6
posted on 21/10/05 at 11:14 AM |
Hi James,
I've used the Cymtriks mods plus quite a few others, the material which is aso used to build the tranny tunnel is 22mm with 1.5mm wall thickness
which should in theory result in a stiffer chassis with no weight penalty.
Paul
