New Topic New Reply
Author: Subject: Mounting Vauxhall red top
paul v6
posted on 21/10/05 at 08:21 PM Reply With Quote
I've decided to fit a 2.0 16v vauxhall red top to the locost (£250 from local yard) but wont get my hands on it for a week or two, this will give me time to fiish the chassis!!
The problem is I dont know how much of a gap I need to leave between the G1 and G2 to house the red top?
Any ideas???
Many thanks
Paul
derf
posted on 21/10/05 at 09:00 PM Reply With Quote
leave them off the car until you get the engine....
MikeR
posted on 21/10/05 at 11:00 PM Reply With Quote
ask NS DEV
ned
posted on 22/10/05 at 07:46 AM Reply With Quote
and look in my archive, stu16v, billy, skippad and there was a thread on this very subject a while back..
Ned.
beware, I've got yellow skin
billy
posted on 22/10/05 at 07:57 AM Reply With Quote
Make sure its strong.......heavy old lump
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
paul v6
posted on 22/10/05 at 09:42 AM Reply With Quote
Thanks Guys,
Having studied the above mentioned photo archives I have another concern
I have a standard book chassis dimension wise but its looking like the XE lump may well protude quite a distance from both top and bottom of the engine bay, I'd prefer not to have to mod the sump and dont really want a bulged bonnet either!!
Is the XE not the ideal choice afterall? Would a 4-age make a more compact alternative?
Many thanks
Paul
[Edited on 22/10/05 by paul v6]
jon_haggerty
posted on 22/10/05 at 12:20 PM Reply With Quote
A ca18det from a 200sx. Although saying this i havnt actually checked the height yet.....
ned
posted on 22/10/05 at 01:18 PM Reply With Quote
Paul,
A 4-age is smaller, but the xe does fit. my car is a standard locost as is nsdev's st locost and stu16v's is pretty standard as is billy's luego locost.
You can get an 8v steel sump cut n shut or buy an expensive ally wet sump from the likes of qed, sbd, westfield etc.
Also remove the belt cover and grind off the belt cover flange on the rocker cover will gain another 3/4". see 'engine positioning photo's in my archive, it will and does fit
Ned.
NS Dev
posted on 24/10/05 at 11:36 AM Reply With Quote
Yep, XE will fit (JUST!!!) under Stuart Taylor std bodywork, which is about as small as 7 bodywork gets.
As Ned said, I have removed the lip at the front of the cam cover (will be running without the front and rear belt covers).
I am using a VERY shallow sump, a caterham HPC one, which is as shallow as a dry sump. You will definitely not get the engine in with a std sump!
here are some pics - Sump and bellhousing under car, side view:
sump clearance
sump clearance
Nearside engine mount, std Stuart Taylor "book" chassis:
Nearside Engine mount
Offside:
Offside engine mount
Dummy engine chucked in:
XE dummy engine front view
New Topic New Reply
