New Topic New Reply
Author: Subject: Water Leak- Tin Top
James
posted on 22/10/05 at 11:31 PM Reply With Quote
Water Leak- Tin Top
Thought this might be relevent to Locost as well so put it here. Sorry for the long explanation.
I've finally got my MK2 Golf back together after the head gasket failure and fired it up for 1st time this afternoon. All appeared hunky dory then noticed a water leak.
It's at the join between the cylinder head and the plastic piece that the water outlet pipe connects too. The plastic piece has a flange that bolts to the side of the head.
The flange has a rubber ring/gasket set into it. I've renewed the rubber ring when rebuilding the head.
The problem is the aluminium face of the head has corroded and cleaning up the head has removed the corroded material and left pitting in the face that the flange bolts to. The pitting is deep enough that the rubber ring/gasket is leaking.
Short of removing the head again and getting the flange face milled flat what can I do?
Is the solution to buy a liquid gasket type stuff (Hermetite or similar?) and effectively fill the pitting with this by making a new/thicker gasket?
Will is survive the heat/pressure?
Thanks for any advice!
James
theconrodkid
posted on 23/10/05 at 12:15 AM Reply With Quote
black silicone sealer....just dont get it on yr hands
who cares who wins
pass the pork pies
fatfranky
posted on 23/10/05 at 02:23 AM Reply With Quote
James
I would use good old silicone too, but if you're really fussy older ie. MK1 golfs used an aluminium elbow with a paper gasket, you could use these if required.
Hope this helps
posted on 23/10/05 at 09:01 AM Reply With Quote
Go with the silicone, just make sure you wear gloves. How did you get the ink off Conrod?
pajsh
posted on 23/10/05 at 09:15 AM Reply With Quote
Worth just checking around the bolt holes on the flange face.
I had a similar problem on my Mk2 Scirocco and there was a hairline crack from inside the bolt holes hole through to the inside of the pipe.
I bought a new plastic part c/w seaing ring and that cured it.
Just a thought.
[Edited on 23/10/05 by pajsh]
Danozeman
posted on 23/10/05 at 09:25 AM Reply With Quote
Id go the silicon route. good stuff.
Dan
posted on 23/10/05 at 09:55 AM Reply With Quote
Nero cam be a bit iffy ---- better CD burners than Nero are available off the net for free --- one of my clients who burnd CD a lot put me wise to CDBurnerXP Pro ( http://www.cdburnerxp.se/ ) which really impressed me.
G.Man
posted on 23/10/05 at 10:00 AM Reply With Quote
JB Weld can build up the metal and be heat resistant...
Its a metal epoxy, the best there is...
Opinions are like backsides..
Ketchup
posted on 23/10/05 at 05:35 PM Reply With Quote
JB weld, saved my ass more than once
James
posted on 25/10/05 at 03:17 PM Reply With Quote
Okay, well popped into Halfords on Sunday on the way back from Walton Mountain beauty spot.
Bought myself some Hermetite Orange Silicon Sealer. Spent ages cleaning it all up with brake cleaner before applying it.
Left it to cure for a couple of hours. Ran it at fast idle for 10-20 mins and all appears fine.
Thank you for the suggestions everybody.
James
ned
posted on 25/10/05 at 03:42 PM Reply With Quote
well done james - but what is british trident on about cd burners for!?
beware, I've got yellow skin
James
posted on 25/10/05 at 04:06 PM Reply With Quote
Originally posted by ned
well done james -
Pity the oil's still going the colour of Baileys!
New Topic New Reply
