New Topic New Reply
Author: Subject: Robin Hood vs. the rest
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
Building: Bought (yeah, I know it's cheating) Sylva Pho
posted on 25/10/05 at 09:38 PM Reply With Quote
Sorry for yet another thread in a similar vein, but I'm a bit clueless!
I'm currently trying to find a nice cheap kit-car to buy, and most of the cars in my budget are robin hoods. I've heard a bit about them, mostly saying they're not very good, but what would be the actual differences between a well put together robin hood and another cheap-ish kit car?
Sam
Metal Hippy
posted on 25/10/05 at 10:02 PM Reply With Quote
About 3 years.
Cock off or cock on. You choose.
Gav
posted on 25/10/05 at 10:27 PM Reply With Quote
From what ive read about Robin hood is that you have to appreciate that they are not aimed to the same niche as other kit car makers.
they seem to be more the fair weather sunday driver type car, rarther than more sporty orientated MNR or MK for instance.
that statement is based on what i have read here and else where so may be completley wrong and if so i blame the 4 cans of coors light i had tonight
Messenjah
posted on 25/10/05 at 11:03 PM Reply With Quote
what i seem to be able to gether from whats been said on here and to me by other people is that
a Robinhood is an ok car aslong as your not aiming it to be a superfast track day special and as was said in th previous reply its more of a sunday driver.
im not an engineer so i wouldnt know but people do not seem to be impressed with their chassis' and build quality varies ALOT builder to builder same is true of any car tho ....
i would guess that a very well put together RH would not be a bad car and it is undoubtebly a rather CHEAPER way to do things
posted on 26/10/05 at 07:31 AM Reply With Quote
In all fairness, they're under new management now, and they seem to have improved a lot. Trouble is, prices have risen as a consequence...
serendipity123
posted on 26/10/05 at 08:00 AM Reply With Quote
if you want a cheap 7, a robin hood is the car for you, a kit a donor and you have a a 7 style car, a 2b (tubie) is a much stronger car and heavier and not as fast, its all about compromise. . .a good start though.
scotty g
posted on 26/10/05 at 08:37 AM Reply With Quote
There is nothing in particular that is wrong with a RobinHood. The 2b is very strong and as a result heavy. The quality is not in the same league as most of the locost based kits and will take quite a bit longer to build but this is all reflected in the price which is extremely competetive.
My first kit was a 2b and my only regret was that i had to sell it.
Having said that, i am now going down the Locost route and the difference in quality is incredible.
steve_gus
posted on 26/10/05 at 09:54 AM Reply With Quote
a RH is based on a sierra. A fair chunk of cars on here are basically rebodied sierras with back axles off 30 year old escorts and no one seems to see that as a problem
atb
steve
http://www.locostbuilder.co.uk
Just knock off the 's'!
posted on 26/10/05 at 12:29 PM Reply With Quote
Under past management RH turned some truly horrible examples of bad engineering that betrayed a real lack of knowledge of automotive engineering. However they were good at cutting production costs to the bone although it usually resulted in truly appalling quality.
The new management is hard trying to push the brand up market but like the reply of legend when stopping for directions in Ireland "Sure if I was going there I wouldn't start from here"
My view would be if you really want an RH watch carefully what happens over the next few months to a year --- but personally woulnd'n't "barge one with touch pole" ;-)
[Edited on 26/10/05 by britishtrident]
posted on 28/10/05 at 01:08 AM Reply With Quote
That's because it's so simmilar to the original Lotus 7. My major gripe with the 2B is the rear suspension, the sierra rear subframe is simply not very suitable for a 7, and results in strange camber angles (unless corrected) and the horrible bulges in front of the rear wings. Most 2B's seem to have huge gaps between the rear wheels and wheel arches as well which don't improve the looks.
New Topic New Reply
