Author: Subject: Damaged bottom wishbones
Hornet
posted on 20/11/05 at 06:46 PM Reply With Quote
Just thought I'd show u guys some damage to my bottom wishbones made Exactly as per the book!!
Only thing I remember hitting is road works old tar to new ramp...
If anyone is making their own parts like me.. i would strengthen the books design.
Cheers J
Sid Hat
Sid Hat
Hornet
posted on 20/11/05 at 06:48 PM Reply With Quote
and another
Sorry for size...
[img][/img]
bigbriglasgow
posted on 20/11/05 at 06:51 PM Reply With Quote
Hi Mate long time no see. Looks quite bad though not a complete fail! r u going to remake new ones or buy a set of prefab from a company?
Brian
coz its a bit of an animal
Ben_Copeland
posted on 20/11/05 at 07:18 PM Reply With Quote
Looks like not enough strength in the plate the suspension bracket was fixed too...
Ben
Locost Map on Google Maps
Enter Your Details Here
SeaBass
posted on 20/11/05 at 07:25 PM Reply With Quote
Looks like you've got about 30 seconds to get those off the kitchen worksurface before you get shot mate... Many design incorporate a 90 bend at the edge of that plate to resist the bending and then plastic deformation you have there... Is this what you were telling me about at Ingliston??
Hornet
posted on 20/11/05 at 09:12 PM Reply With Quote
Yo.. hi Brian.. No not making new ones, gona repair these and strengthen them as per James's comments.
Ben my point is that they were made as per the book.
I would advise anyone else who is gona make their own, to strengthen them before fitting..
Yup James, Cars of the road for winter so mod time.. sump being shortened tonight and repairs to bottom arms..
Looking to fit a screen for next year though
paulf
posted on 20/11/05 at 09:18 PM Reply With Quote
I put an extra 19mm square tube directly under the shock bracket on mine, as I didnt like the look of the original design with no support, I hit some unmarked speed humps at speed and expected to have damaged the wishbones but on checking there was no sign of any damage, maybe you shocks may have bottomed out also ?which would put much more shock loading on the plate.
Paul.
posted on 20/11/05 at 09:21 PM Reply With Quote
Make or buy new ones the book design deeply flawed.No ammount of fiddling will fix that.
omega 24 v6
posted on 20/11/05 at 10:54 PM Reply With Quote
The book shows the suspension bracket plate as being 2mm I was going to make my bones from 25 or 22 mm seamless and up this plate to 3mm possibly with a return of 20mm opposite the balljoint end.
posted on 21/11/05 at 12:19 AM Reply With Quote
I thought the book used 3mm plate for them, that's what I used anyway and I used a piece of the round tube to join the two sides and reinforce where the plate ends.
posted on 21/11/05 at 08:05 AM Reply With Quote
Although it will stop the bending using a thicker plate on top of the tubes will produce a WEAKER wishbone due to the notch effect. The plate should be on the neutral axis of the tubes. MK, GTS MNR all have ditched the book design for a much improved versions.
see this thread http://www.locostbuilders.co.uk/viewthread.php?tid=12587
posted on 21/11/05 at 12:42 PM Reply With Quote
i was going to say from the picture that it looks like 2mm plate, i cant see how ron thought that was good enough.
posted on 21/11/05 at 01:01 PM Reply With Quote
He specifies 2mm for the coil-over mounting plate and 3mm for the Cortina balljoint moutning plate. Certainly very poor engineering in what is a safety critical suspension item.
mangogrooveworkshop
posted on 21/11/05 at 06:13 PM Reply With Quote
Give us a shout we aint too far away in Swanston
Framiss
posted on 21/11/05 at 09:59 PM Reply With Quote
"A" Arms damage
The original lotus RACE car was designed to the absolute minimum weight and strenth. If they could save 1/2 ounce they would. After all the car was repairable after each race. Our cars are street machines and should not compare with out & out race machines.
I add gussetting on all tube contact points, and ad strenght where I think it will help. I do not need a 400 kilo car. I need a street car that will hold up from street conditions. Add a tube under the contact point where the shock tabs are located
posted on 22/11/05 at 09:46 AM Reply With Quote
(1) The original Lotus was a ROAD car and used suspension parts that have nothing in common with the book design that is very roughly based on the pre-lit Westie.
(2) The Bones being sold by GTS, MNR and MK are much stonger and hence heavier. I have a lower wishbone made with plates supplied by Darren at GTS and the plates are 1/4" (6.25mm) thick --- that is over kill but Darren isn't one to take chances with customers lives.
(3) Adding gussets and fillets isn't a good way to solve what is a structural design problem.
SilverFox
posted on 24/11/05 at 08:07 PM Reply With Quote
Porbably asked before, but is there any merit in slotting to a suitable length (75+mm?) the each leg of the lower bone (25 x 16 swg) to create a female to accept a 5 mm lower balljoint plate and weld on both sides. The slot could be initiated with a 5 mm hole drilled then slotted and the plate would be radiused for correct profile in the slot.
Is this stronger or weaker than butt welding the plate on the outside of the tubes?
Framiss
posted on 25/11/05 at 12:32 AM Reply With Quote
Wishbones damage
Look at the thickness of the plate. 2MM is too thin. a bar across the two tubes under the shock tabs should make the difference.
posted on 26/11/05 at 01:47 PM Reply With Quote
Not required as long as the plate is welded on a the neutral axis --- the whole idea is avoid the stress raiser created by welding the plate on the to surface - Darren had a really nice design of lower wishbone but the picture has disapeared from the GTS web site. The MNR wishbones are similar but still have a stress raiser because the plate ends abruptly rather than tapers down.v
[Edited on 26/11/05 by britishtrident]
flak monkey
posted on 26/11/05 at 01:50 PM Reply With Quote
Here is a pic of one of my GTS wishbones. (Slightly different to standard ones, but it illustrates how they should be made.....)
Note that the shock mounting plate is on the neutral axis. And measures 1/4" thick. However the wishbones are not overweight! Infact they are quite light really, considering the heavy construction.
Sera
http://www.motosera.com
NS Dev
posted on 28/11/05 at 12:41 AM Reply With Quote
stuart taylor "book" wishbones use 5mm steel here!!!!
looks well OTT but they don't seem to fail often!
