dr-fastlane
posted on 15/1/06 at 11:48 AM |
autocad 14 problem
The last couple days I have problems with Autocad 14. When I want to store a new drawing I get the report:
Autocad Message:
Permission denied for file: C:\documents and settings\.......\.....\drawingname.dwg.
Or when I open an old drawing:
Autocad Alert:
Unable to write to that directory.
Do you want to continue?
What is wrong?
Roy.
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
jimmyjoebob
posted on 15/1/06 at 05:18 PM |
Check your virtual memory - my work computer used to grind to a halt and refuse to save anything especially with 2D cad.
dr-fastlane
posted on 16/1/06 at 06:13 PM |
Thanks, autocad is running agian. I had not enough space on the c drive. So now I saved the drawings to the D drive everything works well.
Greets Roy.
