IWantOne
posted on 16/3/06 at 01:31 PM |
Battery in MK Blackbird
the battery is my MK is knackerd. its a std 12v 40a car battery. do i buy a bike battery or just replace like for like? will the std car battery do
any damage as i believe the bike battery is only 10a?
thanks in advance
ady
[Edited on 16/3/06 by IWantOne]
ChrisGamlin
posted on 16/3/06 at 01:42 PM |
You can use either car or bike battery, the Ah (Amp Hour) rating doesnt matter as its basically just additional capacity so you could turn the engine
over longer without it going flat, and the cranking current is how much current it can provide if required, but as long as they are above the minimum
requirements for the engine, thats fine
A bike battery is significantly lighter though so is a good reason to choose one, something like a Yuasa/Varta YTX12. You can get them from Halfords
etc but probably cheaper from somewhere like MDS Batteries who sponsor the RGB BEC race series so will be able
to recommend the correct one.
Chris
[Edited on 16/3/06 by ChrisGamlin]
Phil.J
posted on 16/3/06 at 01:46 PM |
Battery
Stick with what you've got unless you are after ultra-light weight. As long as it is 12v there will be no problems with a bigger amperage, and
it will be more durable if, say, you are out at night and the alternater goes pop.
IWantOne
thanks a lot Chris. not to bothered about the extra few lbs. not going to slow the beast to much!!!! has been a pig to start as the choke wasnt
connected!! killed the battery.
IWantOne
posted on 16/3/06 at 01:47 PM |
looks like a car battery it is then..thanks guys
ChrisGamlin
posted on 16/3/06 at 01:52 PM |
Yep, go with whatever is cheapest / best for you, the only other advantage of a lighter battery is that its significantly easier to mount a 3kg
battery in the car securely than it is a 7-8kg one, however they do tend to die far more easily than a big car battery so if you havent got a battery
conditioner charger (Optimate etc) to keep it alive over the winter then a car battery may be better.
Chris
mandbsheldon
posted on 16/3/06 at 02:16 PM |
Does having a car/bike battery have any affect on the rectifier?
Leigh
mandbsheldon
posted on 16/3/06 at 06:31 PM |
Thanks Charlie!
Leigh
IWantOne
posted on 16/3/06 at 08:45 PM |
thanks guys
