nitram38
posted on 22/4/06 at 08:29 AM |
Pipe/Tube Notcher
Anyone got one for sale or know where I can buy one?
CommanderAce
posted on 22/4/06 at 08:33 AM |
There is one here
nitram38
posted on 22/4/06 at 08:39 AM |
quote: Originally posted by CommanderAce
There is one here
Cheers for the link, but I try to avoid them if possible as their prices are generally higher, but I will use them if I can't do better
elsewhere.
zilspeed
posted on 22/4/06 at 08:49 AM |
Do you have a drill stand ?
One of these, a hole cutter and a jig for holding the pipe is all that's really required.
the_fbi
posted on 22/4/06 at 08:50 AM |
Probably not the best quality, but
http://cgi1.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4442471530
Sort of thing which given access to a mill/lathe you could make yourself in an hour.
Then again, if you had access to a mill you could notch your own pipes too.
[Edited on 22/4/06 by the_fbi]
nitram38
posted on 22/4/06 at 08:56 AM |
Looks like I may have to buy it from Demon!
Thanks Guys
nitram38
posted on 22/4/06 at 09:44 AM |
Ordered from Demon. Cost £89.10 delivered, including vat.
I needed it as my next project will be an exposed chassis and a lot of it will be tig welded and on show.
pathfinder
posted on 22/4/06 at 10:03 AM |
thats not a bad price rollcentre racing are asking £150 for one pluss £20 postage ![](/images//smilies/shocked.gif)
Minicooper
posted on 22/4/06 at 10:19 AM |
I know I bought one, didn't even think about Demon Tweaks having them, at least the quality is excellent
I'm now depressed
Syd Bridge
posted on 22/4/06 at 10:39 AM |
The problem with the cheap ones, is that they use an electric drill to spin the hole saw. And, a leccy drill just does not turn slow enough.
A 1" holesaw only needs about 300-400 rpm, at most. My experience has shown me that 150-200 is OK. Lube with WD40 or cutting fluid.
Then there is the problem with drills trying to break your wrists when they jam!
Holesaw in a drill stand or mill, or a side and face cutter in the lathe or mill, are the better ways of doing the job.
Syd.
nitram38
posted on 22/4/06 at 10:47 AM |
The one from Demon can be bolted via the foot onto a drill press.
[Edited on 22/4/2006 by nitram38]
