New Topic New Reply
Author: Subject: Weighed at last!
posted on 12/5/06 at 08:49 PM Reply With Quote
Weighed at last!
I finally got round to getting my car weighed today, at my local weighbridge - I've been driving it for over a year and a half!
Considering that it's a standard chassis with a car engine, steel floor, and no special effort to keep it light, I was very pleased that it came out at 600kg ( +/- 20kg) with a half-tank of petrol.
David.
Surrey Dave
posted on 12/5/06 at 08:52 PM Reply With Quote
What was the axle weight at SVA ? , does that not relate to the total weight?
iank
posted on 12/5/06 at 09:48 PM Reply With Quote
Not by simply adding them no, if you do that I think the weight comes out rather lower than actual weight.
I think if you could figure out the exact COG of the car you could theoretically work it out with lots of trig and simultaneous equations, but practically speaking it's far easier to go the the weighbridge.
600kg sounds a good weight for a CEC.
welderman
posted on 12/5/06 at 09:49 PM Reply With Quote
Bloody strange that, had my MK Blade on the scales today too. 500 kg +/- 20kg, full tank of fuel.
Strange that eh!.
Thank's, Joe
I don't stalk people
flak monkey
posted on 12/5/06 at 10:29 PM Reply With Quote
All you need is the location of the CoG between the axles. Then its just moments. Pretty simple stuff, but most people wont know where the CoG lies.
Weights are around what I would expect, some of the weights quoted recently in another thread worried me somewhat!
Sera
http://www.motosera.com
iank
posted on 12/5/06 at 10:52 PM Reply With Quote
Yep, knowing the CoG is the hard bit. Doing moments would probably tax this old brain for a while, not done any significant maths since I left school
Were the weights too high or too low? I suspect a lot of people just add the axle weights.
posted on 12/5/06 at 11:42 PM Reply With Quote
Adding the axle weights should give the total car weight unless they were not measured properly (e.g. car not perfectly horizontal when measured).
DaveFJ
posted on 13/5/06 at 07:51 AM Reply With Quote
The total of the axle weights will give all up weight. from the two axle weights you can calculate the CofG easily (longitudinaly anyway). If you want lateral Cofg you need the weights at all 4 wheels.
Dave
DaveFJ
posted on 13/5/06 at 08:00 AM Reply With Quote
to calculate CofG just remember
Wt =W2+W1
measuring from W1 you ignore the weight at W1....
therefore
a x WT = (a + b) x W2
as you know what a+b equals and what Wt, and W2 are you can solve for a and thus b as well....
Dave
flak monkey
posted on 13/5/06 at 08:49 AM Reply With Quote
Total of the weights at SVA will give you a weight less than that of the whole car. i believe they are measured seperately so...
The car can be modelled as a beam. The CoG being the load, one axle being a pivot point, the other being the force measurement point.
The load is not directly above the point where the force measurement is being taken so moments come in to play, which as far as i can see will always reduce the total weight of the car.
Theres a bit about it in the SVA manual IIRC laid out slightly differently though.
Of course if both axle weights are measured at the same time then the total weight is that of the car.
Sera
Dave Ashurst
posted on 13/5/06 at 08:54 AM Reply With Quote
So how does the axle weighing machine know whether the other end of the car is on a set of scales or not?
flak monkey
posted on 13/5/06 at 09:04 AM Reply With Quote
Actually it doesnt make the slightest bit of bloody difference does it? The sum of the reaction forces at each wheel will always equal the total weight of the car.
Jeez you can tell I havent done any real maths for 2 years.
Sera
posted on 13/5/06 at 12:10 PM Reply With Quote
Strange that eh!.
When I typed my meggase I just KNEW that some BEC builder would under-cut me by a mile!
I don't care... I'm happy with my result!
BTW: At my SVA the design weight was listed as 800kg on the forms - 350kg axle 1, 450kg axle 2.
welderman
posted on 13/5/06 at 10:51 PM Reply With Quote
Strange that eh!.
No offence there, i meant that it was strange we both had ours done.
Joe
Thank's, Joe
NS Dev
posted on 14/5/06 at 12:18 AM Reply With Quote
Was getting worried there, you are doing engineering aren't you???
(only kidding!!)
Simplest way is if there is a level run up to your weighbridge, park the front on an weigh it, then the back, then the whole car as a double check, job done.
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 14/5/06 at 08:33 AM Reply With Quote
if it isnt on a perfect level then the 2 axle weights if measured on the same scales (ie measure front the turn the car round and measure the back) wont add up to the total weight but it would have to be seriously of level to make any real difference (ie enough to be out of the +-20kg)
posted on 14/5/06 at 06:04 PM Reply With Quote
No offence taken, Joe!
It is nice to know exactly how much your car weighs, isn't it - I've been saying "Oh, it's about... whatever" but never really knew for sure.
With a bike engine instead of my xflow & Mk9 gearbox it would probably be 75kg lighter.
Mabye sometime in the future...
New Topic New Reply
