New Topic New Reply
Author: Subject: Liquid filled gauge
givemethebighammer
posted on 28/5/06 at 11:28 PM Reply With Quote
Liquid filled gauge
I picked up a cheap corner weight gauge from ebay last week. When it arrived the rubber bung in the top of the liquid filled gauge that it uses to measure pressure(0-1000psi) (and hence weight) had come out and most of the liquid had leaked out. The gauge still appears to work, but what do I refill it with ? do I need to refill it ? (jack oil came to mind)
Big Ali D
posted on 28/5/06 at 11:58 PM Reply With Quote
The gauge should work fine without the liquid,
its just to dampen the needle movement
Fred W B
posted on 29/5/06 at 07:32 PM Reply With Quote
As stated, will still work. Most probably it would have been filled with Glycerene
Fred W B
givemethebighammer
posted on 30/5/06 at 08:53 PM Reply With Quote
thanks, I guess I'll leave it unfilled then.
New Topic New Reply
