Ferg
posted on 25/6/06 at 10:22 AM |
Anyone built a Velocity XT with drum rear brakes???
If so, what cables did you use for the handbrake? 'Old' Luego said 'Allegro'...but I find they are too short.
posted on 25/6/06 at 12:30 PM |
Ferg , do your cables come out of the rear of the upright going towards the front or the rear of the car? mine come out of the front but I seem to
have a fair bit of slack . Think the drive shafts were shortened by approx 2" but appear to have more than that slack
Ferg
posted on 25/6/06 at 01:45 PM |
Hmmm...
You gave me a heart attack there! I rushed out because ours come out of the back and it would mean swappng them side to side to alter it! However, I
offered a cable up to the mounting bracket and threaded it through to the drum and it wouldn't go that way either AND pictures in the Luego
Comedy-Book-Of-Fiction (AKA Build Manual) show the cable coming from the rear.........
Someone must have done this before...
posted on 25/6/06 at 02:46 PM |
In that case all I can suggest is if no one comes up with a suitable cable is to work out how much longer you need the cable to be and try your local
friendly motor factors to see if they can come up with a pair. Something like a Peugeot 106?306?
Danozeman
posted on 25/6/06 at 07:21 PM |
Xt's are independant arnt they??
Sierra brakes pull from inside not outside the the live axle?? Could u not use the sierra cable and maybe chop it if needed? Iv got a MK4/5
fiesta cable on my cortina axle. Its a tad too long but is ok.
Dan
Mark18
posted on 25/6/06 at 09:22 PM |
I just shortened the sierra cable using the "bolt with hole in it" method.
Ferg
posted on 26/6/06 at 06:02 PM |
The Sierra cable is one complete thing side to side isn't it? How do you anchor the outer (twice)??
Ta.
Mark18
posted on 27/6/06 at 12:31 PM |
http://locostbuilders.co.uk/viewthread.php?tid=40255
