Math
posted on 30/6/06 at 04:15 PM |
Front Wheel guards
The front wheel guard brackets on my Luego Velocity are supposed to fit onto the ball joint threads, there is only one or two threads to tighten the
nut up against.
Any suggestions would help
Math
Humbug
posted on 30/6/06 at 04:58 PM |
Not sure if it helps, but if they are like the ones I had on my Westy with Cortina uprights, I had to grind a bit of the upright away so the bracket
fitted on with enough space to do up the nut.
posted on 30/6/06 at 05:15 PM |
Think if you do a search this has been covered several times. It seems that some makes of Transit joint have shorter threads than others. HTH
