davrus
posted on 9/7/06 at 07:05 PM |
1.3 crossflow sprrdo
hi ya , i have a 1300 crossflw with a 4 speed box , can any one tell me what speedo is the best to use for acuracy
Many thanks
posted on 9/7/06 at 07:09 PM |
Speedo would depend on diff ratio and tyre size , electronic speedos can be calibrated in a few seconds after a few small calculations
davrus
posted on 9/7/06 at 07:12 PM |
is it a dear job to have an electronic one , does it mean i need a digital clock or if not what clock is the best to use.
Thanks for you advise
posted on 9/7/06 at 07:24 PM |
It's possible to use loads of different speedos , a lot of them can be calibrated but it's not a DIY job . Had a Mini one done a few
years ago by Speedy Cables , speedo was cleaned, serviced and recalibrated for about £30 IIRC cost will have gone up a bit but not sure by how much
Ford one can be calibrated by changing the speedo drive gear in the gearbox but which gear to use ?
UncleFista
posted on 9/7/06 at 08:25 PM |
I've used a bicycle speedo for the last few months, was less than a tenner and it's stuck on with blu-tak
Is it possible to get any cheaper/easier (or lazier for that matter) ?
Tony Bond / UncleFista
