New Topic New Reply
Author: Subject: copper petrol pipe
madteg
posted on 20/7/06 at 06:01 PM Reply With Quote
copper petrol pipe
is copper ok or what should i use?
fesycresy
posted on 20/7/06 at 06:17 PM Reply With Quote
microbore is fine
iank
posted on 20/7/06 at 09:02 PM Reply With Quote
There was some concern (from a fuel system professional IIRC) that the copper could leach out over high mileages (>100k?) and block the injectors.
So probably not a real problem for a fun car, and most people have used it without obvious hitches.
wilkingj
posted on 20/7/06 at 09:33 PM Reply With Quote
I used 8mm microbore central heating tube, and covered it with split convoluted tubing to protect it.
Got through the SVA OK.
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 20/7/06 at 09:38 PM Reply With Quote
ive seen a lot of rubber pipe perish, so i would personally prefer copper in the long run. Seems more durable.
RazMan
posted on 20/7/06 at 10:16 PM Reply With Quote
Apparently the Kunifer pipe is stronger than the usual brake pipe - that's what I used to link my twin tanks.
Raz
DIY Si
posted on 20/7/06 at 11:08 PM Reply With Quote
As said, kunifer pipe is best as it's stronge than plain copper. Also, copper pipe is only supposed (I think) to be single use. IE if you ever unscrew a union, that pipe should be changed. Can't rememebr where I heard this, so might be complete rubbish.
posted on 21/7/06 at 07:51 AM Reply With Quote
I did some Goolge research on this - it seems that the only real problem is where the car is used with low-grade petrol that contains a lot of sulphur (you won't find this in the UK). Eventually the fuel system get clogged up with copper sulphate/sulphide or something like that.
[Edited on 21/7/06 by David Jenkins]
iank
posted on 21/7/06 at 08:44 AM Reply With Quote
Just for completeness here is the thread I was talking about.
http://www.locostbuilders.co.uk/viewthread.php?tid=44395&page=2
andyace
posted on 21/7/06 at 10:30 AM Reply With Quote
Originally posted by fesycresy
microbore is fine
Is there a difference between normal copper plumbing pipe from b and q and microbore. What I am asking really is what is microbore?
I ask coz I want to pop out today and get some 8mm copper pipe and don't want to get the wrong stuff, does it come in straight lengths or in a roll?
posted on 21/7/06 at 10:40 AM Reply With Quote
Usually comes in a roll about 500mm across. As far as I know, if you find 8mm copper pipe rolled up in B&Q, it's microbore and it's the stuff you need.
posted on 21/7/06 at 10:54 AM Reply With Quote
Out of interest (and vaguely on topic) - what are the alternatives to copper?
I currently use rubber fuel pipe, but I am getting concerned about the surface cracking I'm seeing, especially at the back where it's exposed to road muck.
I have seen people with plastic-coated aluminium pipe, but I wouldn't trust alu. pipe for fuel as it work-hardens and is likely to fracture (or am I being paranoid?)
Braided hose is expensive. Pretty, but expensive.
Can you get plastic hose designed for petrol lines?
timf
posted on 21/7/06 at 11:50 AM Reply With Quote
you can get plasic pipe designed for petrol
just look under a ford xr3i but never found anyone who sells it on a roll
A prisoner of war is a man who tries to kill you and fails, and then asks you not to kill him."
- Sir Winston S. Churchill, 1952
robertst
posted on 22/7/06 at 12:01 AM Reply With Quote
sorry... so copper microbore pipe and whatnot is also suitable for the braking system? i had the notion that it was not allowed by sva or that kunifer was the only real thing suitable for braking...
people in motor factors here tell me that it's ok to use copper for the braking system...but i give them the eeevil eye
Tom
iank
posted on 22/7/06 at 07:32 AM Reply With Quote
The copper microbore that is being talked about is used for plumbing in central heating systems and is NOT suitable for brakes.
You can use suitably rated copper pipe for brakes, but it's an inferior material to Kunifer. Kunifer is a copper alloy which is harder and doesn't suffer from work hardening (like pure copper or aluminium).
[Edited on 22/7/06 by iank]
Schrodinger
posted on 26/7/06 at 11:15 AM Reply With Quote
I have used plastic pipe in a Tiger Cat the fittings were basic brass compression fittings and the pipe came from a local (Ipswich) HGV factors
New Topic New Reply
