matt_claydon
posted on 27/7/06 at 10:30 AM |
Need stainless welded in Bristol
I need to get a boss for a lambda sensor welded onto my stainless exhaust. I have the boss (also stainless) and just need it fitted. Would the average
exhaust place do this or do they usually only deal with mild steel? Is there anyone local on here who would do it for beer tokens?
Matt.
tks
posted on 27/7/06 at 11:05 AM |
mhh
would just be a normal Tig / argon jobbie..
should be easy!
in fact you even don´t need to add material because it will flow away from the nut...
if you was here i would do it for free..
Tks
John Bonnett
posted on 27/7/06 at 11:17 AM |
If you have a problem getting it TIG welded it can be brazed without any difficulty and this is a job anyone with oxy acetylene would do for you.
I did mine this way 8 years ago and it is still ther!!
John
bob
posted on 27/7/06 at 12:57 PM |
matt you have mail
