Author: Subject: Autogauge gauges, acceptable?
the_fbi
posted on 13/8/06 at 05:36 PM Reply With Quote
I know they are cheap, so I'm guessing there are quality issues with them?
Anybody have first hand use of either the 270 or 360 degree 52mm oil temp/pressure or water temp gauges?
Diff styles below.
Considering I can get all 3 x 360 for sub £72 or all 3 x 270 for £56, all with electrical senders, worth it or should I shell out for SPA dual LCD's?
[Edited on 13/8/06 by the_fbi]
the_fbi
posted on 13/8/06 at 05:38 PM Reply With Quote
2nd pic.
the_fbi
posted on 13/8/06 at 05:59 PM Reply With Quote
Well if they're good enough for you......
ta
Chris
omega 24 v6
posted on 13/8/06 at 06:25 PM Reply With Quote
They looked good to me on Friday when I saw them. Certainly in my "must look into folder"
Guinness
posted on 13/8/06 at 06:51 PM Reply With Quote
I have the oil pressure and oil temp in the 360 degree version in your second picture.
They are OK, the temp one is fine, but I find the pressure one wobbles with vibration. At steady revs it can vibrate quite a bit, almost like there is no damping in the needle?
But then I can only compare them to OE gauges installed in tin tops, having never used other aftermarket brands I can't compare them.
HTH
Mike
john_p_b
posted on 13/8/06 at 07:15 PM Reply With Quote
glad someone mentioned these as i'm looking at boost, water temp and oil pressure gauges for my cosworth and these are quite appealing both in price and style. i'm looking at the stealth ones they do.
mark, do you know what the outter diameter of the bezel on the gauge is please?
built a car, built a home, had a family. lost the family, lost the home, still got the car.
the_fbi
posted on 13/8/06 at 07:42 PM Reply With Quote
Found these earlier......
http://cgi1.ebay.co.uk/ws/eBayISAPI.dll?MakeTrack&item=170017888420
john_p_b
posted on 13/8/06 at 07:54 PM Reply With Quote
thanks mark, had a bit of a panic then as i was looking at the 52mm gauges which led to a bit of a when you said 72mm!
cheers
the_fbi
posted on 13/8/06 at 07:55 PM Reply With Quote
Both the ones I pictures are 52mm, which is 2 1/16"
The larger ones are 2 5/8"
Crazy Jay
posted on 13/8/06 at 09:35 PM Reply With Quote
I've got these ultra lite ones in the SX and they're quite nice. Best bit they light up blue
Thinkin of gettin the oil pressure and temp gauges for the MK
Link to gauges
[Edited on 13/8/06 by Crazy Jay]
the_fbi
posted on 13/8/06 at 10:30 PM Reply With Quote
Jay: Auto Meter is a different kettle of fish to Auto Gauge though. At opposite ends of the price spectrum
I've got an Auto Meter boost gauge on my LET, worth every penny, but they start at £45 for a mechanical oil pressure gauge which is just plain silly.
Crazy Jay
posted on 13/8/06 at 10:41 PM Reply With Quote
Ah sorry didnt read the prices of the autogauge ones
grusks
posted on 14/8/06 at 06:28 PM Reply With Quote
Its a shame they dont do a fuel level or speedo as ive been looking at these for a while but want a complete matching set.
Spence
Need More Money
the_fbi
posted on 14/8/06 at 09:13 PM Reply With Quote
http://www.autogauge.com.tw
Steve Lovelock
posted on 14/8/06 at 09:34 PM Reply With Quote
I could only find a speedo that had 0-300 KPH which is not much good for an English 7, have I missed it then?
posted on 15/8/06 at 07:40 AM Reply With Quote
Just been through the entire range on the website and no sign of a fuel level gauge, and only speedo's in kmh which is a shame.
posted on 15/8/06 at 01:40 PM Reply With Quote
Originally posted by CaLviNx
A trip to the opticians might be in order Mike
I admit I did miss the speedometer but I looked again through the entire "performance" range and there were no fuel level gauges.
They do make a fuel gauge for "yacht" applications that would no doubt be suitable for a car, except it is available in only one style which dosen't realy match any of the performance range. I think the original statment stands in this case (unless you are happy with a set of brand new but unmatched instruments in your build).
grusks
posted on 15/8/06 at 09:58 PM Reply With Quote
I found the fuel gauge under the yacht section - not sure if the sender unit will work on a car tank unless there the same size ish, i think ill drop them an email for some prices etc.
Need More Money
the_fbi
posted on 15/8/06 at 10:06 PM Reply With Quote
The sender Westfield supply is the VDO one designed for boats. The good thing is it is easily cut down for a shallow tank.
Nothing to do with the Autogauge ones though
Fred W B
posted on 16/8/06 at 08:17 AM Reply With Quote
I got a matching Autogauge set with fuel gauge and sender at the local "go fast" shop no problem. Poor pic here of dash mock up
Fred W B
[img][/img]
