motorcrossrider
posted on 15/8/06 at 02:53 PM |
Quaife Quick steering rack
Has anybody got any experience of the Quaife quick steering rack? Just wondered if it was a worthwhile purchase or not?
muzchap
posted on 15/8/06 at 03:16 PM |
I have an MNR quick rack - it's excellent
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Jasper
posted on 15/8/06 at 03:22 PM |
depends if you want to go fast around tight bends! I found mine rather twichy on country lanes.
nitram38
posted on 15/8/06 at 04:05 PM |
Better ratio Steering should not make your car "twitchy". Only the wrong setup or poor castor can do that.
Try increasing your castor angle if you can.
My car is 1 1/4 turns lock to lock and she hugs bends without any twitches.
The only twitches come from my underpants!
[Edited on 15/8/2006 by nitram38]
posted on 15/8/06 at 05:53 PM |
my preference would be for the quickest rack possible with enough castor to keep it straight. My new top bones will be castor adjustable, if i ever
get round to making them. The rack i have is quick but not enough (2.9?)
procomp
posted on 16/8/06 at 07:27 AM |
Hi as said above it's not the quick rack that makes the car to twitchy it the setup.
Dont expect quaife to produce any kits soon as both myself and stuart taylor have had 25 kits each on order for over 12 month and they just
can't be ar**d to get them done.
cheers matt
posted on 16/8/06 at 07:46 AM |
I have a Rally Design quick rack - but that's a Escort type - they don't have Sierra ones.
For me it was toe-in that affected the handling - originally I had zero toe-in, and that was very twitchy. Put on a little bit of toe-in and it got
quite civilised.
