Kamikza
posted on 26/8/06 at 01:12 PM |
Huston we have a problem
i broke my pcket bike ,it had pull to start sistem and it fell a part the pull thingi and now i was thinking of conwerting to electr5ic start ???There
is no parts for that bike in Croatia
| posted on 26/8/06 at 01:50 PM |
Then you'll need a battery, stick with the pull start. Stick something on the pulley and try turning it over with an electric drill
| posted on 26/8/06 at 01:54 PM |
pull cords always break, you just need to take it apart and fix it!
Kamikza
| posted on 26/8/06 at 02:02 PM |
i konwe that i can fix it but the konektor that links the engen and the pull cable broke into milion pices dril you say i go test it out
Kamikza
| posted on 26/8/06 at 05:27 PM |
nower to conect the drill ther are pgotos of how it looks like
| posted on 26/8/06 at 05:39 PM |
the photo shows the side with the cord in it, is the engine side as mangled as that?
You could try using a spade drill bit into a groove that you could make on the engine side of the spinner. Makes it easy to pull out quick when it
fires up.
Kamikza
| posted on 26/8/06 at 05:58 PM |
HERE
| posted on 26/8/06 at 07:21 PM |
You'd be better looking for parts on a lawnmower or chainsaw for the recoil starter. Lots of them use that system.
Kamikza
| posted on 27/8/06 at 06:53 PM |
i did a solition i pot a plastiic part directli to the rotor and you yust warp the rope and pull it is sili since you have to wrap it everi time you
pull and it will not start from the frst time
