Fred W B
| posted on 30/8/06 at 08:14 AM |
Interesting crash details
Here - scroll down
From Tim Hoverd's excellent Fury build/race diary
Fred W B
[Edited on 30/8/06 by Fred W B]
MartinDB
| posted on 30/8/06 at 09:56 AM |
I normally enjoy reading his diary but not this time .
Martin.
ned
| posted on 30/8/06 at 11:41 AM |
booger.
is this a bad time to mention that he says his rear upright broke, guessing it's a fisher part though?!
Ned.
beware, I've got yellow skin
andylancaster3000
| posted on 30/8/06 at 12:35 PM |
I was standing at copse for the RGB race and it certainly was a heavy thump!
Fred W B
| posted on 30/8/06 at 03:03 PM |
I am very impressed with the fact that in spite of an impact that was hard enough to break two wheels almost clean off the car, including -
The rear left drive shaft had been ripped in two, tearing the inner CV joint apart in the process.
The rear left upright was broken.
All three rosejoints holding the left rear upright on had sheared, as had the brake hose.
The lower wishbone had been rotated rearwards and in the process had pushed into the diff carrier twisting this part of the chassis seriously.
that the new wishbones he had made himself during the 05/06 winter rebuild stayed together!
I have mailed him to ask what size and grade of material they were made from. I scanned back though the diary but I didn't see anywhere that he
states this.
Fred W B
Jon Ison
| posted on 30/8/06 at 04:08 PM |
After this accident at Cadwell I built in "weakness" too the wishbones as the fact they where too good/strong caused more chassis damage
than the impact, surely its better they rip off rather than take 1/2 the chassis with them as they have no give ?
cossey
| posted on 30/8/06 at 04:38 PM |
quote: Originally posted by ned
booger.
Ned.
the upright was the other side unless hes broken 2 of them now (they are a fisher part so not difficult to replace)
this is where that wishbone used to be
his build diary is what finally put me off trying a season of the rgb i cant afford to be repairing/replacing anywhere near as much as he has to.
[Edited on 30/8/06 by cossey]
timhoverd
| posted on 30/8/06 at 10:55 PM |
quote: From Tim Hoverd's excellent Fury build/race diary
Cor! Fame at last! I'm being discussed on LocostsBuilders!
The wishbones, btw, as someone was asking, are made from 7/8" OD 16swg CDS 2 tubing with weldable rosejoint bushes bought from Rally Design and
turned down on a friend's lathe to fit the aforementioned tubing.
The fact that they're CDS does make them a heck of a lot stronger than normal ERW tubing. You can just tell when you move a 6 metre length of it
around how rigid it is.
Tim
Fred W B
| posted on 31/8/06 at 05:51 AM |
Tim - Thanks for reply
Correct me if I'm wrong here, but another point to note is that the wishbones were tig welded.
Fred W B
timhoverd
| posted on 31/8/06 at 07:49 AM |
quote: Correct me if I'm wrong here, but another point to note is that the wishbones were tig welded.
Actually, they weren't. I did have a TIG at the time and could have done them with that. However, I think I'd have still been doing it.
They were done with MIG, using an argon/CO2 mix gas. The welding isn't of the prettiest but it obviously works!
Tim
timhoverd
| posted on 31/8/06 at 06:03 PM |
While I'm on here. Do you locost chaps have a source for ready made suspension brackets? (The U-shaped bits that are in the photo at the top of
the page with the rosejoints bolted into them.)
That is, do I really have to bash a piece of steel to the right shape or can I buy them somewhere?
Tim
Guinness
| posted on 31/8/06 at 06:14 PM |
MNR do them.
Wishbone / coilover chassis mounting bracket 3mm mild steel with M12 hole each @ £1.90
But I guess any of the major manufacturers MK, MAC1 etc would do them too!
Just found these on GTS site.
GTS-004 Suspension Bracket U bracket to suit GTS polybushes £1.55 each
Hope that helps and good luck with the rebuild.
Mike
[Edited on 31/8/06 by Guinness]
Jon Ison
| posted on 31/8/06 at 06:17 PM |
Tim, this is the reason you ain't seen much of me this season, but the chassis sustained very little damage due too the wishbones breaking away
during impact...........
re build funds, (lack of) have kept me away.
timhoverd
| posted on 1/9/06 at 08:16 AM |
quote: Originally posted by Guinness
MNR do them.
Cool, thanks. Just what I need.
Tim
timhoverd
| posted on 1/9/06 at 08:19 AM |
Jon,
quote: Originally posted by Jon Ison
Tim, this is the reason you ain't seen much of me this season...
Ah, hmmm, yes, not good.
Didn't I hear that you'd acquired the chassis for that thing that was in the TV programme I was in? (Or am I very confused?)
Tim
Jon Ison
| posted on 1/9/06 at 09:02 AM |
your sorta confused.......
I nabbed the bodywork, the chassis looked a bit suspect when I saw it in its bare bones state.
