Author: Subject: Engine pre '95 enquiry
Jazzy
posted on 22/9/06 at 12:20 PM Reply With Quote
Hi, can you tell me if i do need to fit a pre Aug '95 into my kit car? Many thanks in advance.
James
posted on 22/9/06 at 12:26 PM Reply With Quote
Well I certainly haven't fitted a "pre Aug '95" into my car!
Frankly it just didn't fit!
James
James
posted on 22/9/06 at 12:27 PM Reply With Quote
Sorry, being silly.
If you mean engine then no, you can fit any engine in.
The point is, that if it's pre 95 then it won't need a Catalytic converter.
James
Danozeman
posted on 22/9/06 at 12:30 PM Reply With Quote
AS James said mate. U can fit what u want. Just fit pre 95 for easier emissions test.
Dan
posted on 22/9/06 at 12:35 PM Reply With Quote
To get your car on the road, it will first have to pass an SVA test. Part of this test is based on emissions. These fall into two categories depending on the age of your engine - pre 1st August 1995 and post 1st August 1995. The latter test is more stringent and will require a Catalytic Converter to pass.
Apologies if you already knew some of this.
Phil
alanr
posted on 22/9/06 at 01:32 PM Reply With Quote
I don't think you need to have a Cat - you just need to pass the emmisions requirements
A
posted on 22/9/06 at 04:04 PM Reply With Quote
A
Which you can't do with a post 95 engine without a Catalytic converter.
Mark Allanson
posted on 22/9/06 at 08:28 PM Reply With Quote
My 2.0i pinto would have passed the post 1st August emissions test without a cat, I just leaned it back and the engine was in good condition (190psi on all 4 bores)
Phil
Colnago_Man
posted on 9/10/06 at 07:59 PM Reply With Quote
How does the SVA man know how old my engine is?
iank
posted on 9/10/06 at 08:11 PM Reply With Quote
You have to prove it to him.
Usual method is to send the engine number to a Ford department (search to find details) and they send back an official letter.
Most other manufacturers have similar departments.
Macbeast
posted on 10/10/06 at 06:00 AM Reply With Quote
If it's a Ford engine, the first two letters of the engine number give the date of manufacture, eg FM12345 is March 1985.
There is a table of engine date / two-letter code in the Burton catalogue (and if you don't have one, you should ) and people on here have said that SVA man accepts that table as evidence of engine age.
