New Topic New Reply
Author: Subject: water pump zetec
madteg
posted on 14/10/06 at 09:24 PM Reply With Quote
water pump zetec
Putting 2.0l in, does anybody know what water pump i need as this one goes in the wrong direction, part number if poss, THANKS.
big_wasa
posted on 14/10/06 at 09:33 PM Reply With Quote
here you go eBay link ! £26 to your door Dont forget you will also want the toothed drive pully to go with it .
ProjectX
posted on 14/10/06 at 09:50 PM Reply With Quote
Hi, Sorry to jump in on this thread, but where can I get the toothed pulley for above said WP?
big_wasa
posted on 14/10/06 at 10:31 PM Reply With Quote
Best bet is the scrapie.
I pay £1-2 each.
I may get a few more next time I am down there and post at cost, as I have done with a few other bits and bobs.
Its a five min job on an escort. 4 bolts with 8mm spanner cut the belt and mind your nuckles as you pull it past the chassis leg
Dusty
posted on 14/10/06 at 11:04 PM Reply With Quote
That water pump fits silvertops only. If you are fitting a blacktop you have to live with the wrong way pump it comes with and add an idler pulley to drive the pump the way it was intended by ford off the back of the belt.
big_wasa
posted on 15/10/06 at 09:54 AM Reply With Quote
Yeh Good Point I just asumed it was a Silver top
ChrisW
posted on 18/10/06 at 08:06 PM Reply With Quote
In case you havn't already figured this out.... the 2.0 Mondeo pump runs the opposite way to the 1.6 and 1.8 Escort ones. I guess most people will use the inlet off an Escort, so just remember to grab the water pump (and the injectors and TB) at the same time!
Chris
New Topic New Reply
