alanr
posted on 26/10/06 at 01:11 PM |
MOT and emissions
A general question to all you bike car people but possibly more to Marc at MNR
My first MOT will be due next year - the car was registered in 2004 albeit on a ""G"" plate relating to the donor and has a
'97 Fireblade
How will I be able to pass the emissions part of the MOT as the MOT man will have to comply with the emission figures detailed on the Registration
Document --- any help or advice would be appreciated
A
[Edited on 26/10/06 by alanr]
Jubal
posted on 26/10/06 at 02:12 PM |
Interested too. I am in the same boat next year. But my V5 hasn't got any figures in there for emissions.
G.Man
posted on 26/10/06 at 03:23 PM |
Age related so its that applicable to a G-Reg car...
Opinions are like backsides..
alanr
posted on 26/10/06 at 03:36 PM |
I hope you are right Gman - I need to check the figures that are on the Reg Doc but if it is age related as you suggested, how has the car got away
with no MOT for the first 3 years
A
russbost
posted on 26/10/06 at 04:06 PM |
Take a look here:-
http://www.locostbuilders.co.uk/viewthread.php?tid=52224
G.Man
posted on 26/10/06 at 05:40 PM |
A
All kit cars that go through an SVA are exempt from MOT for first 3 years..
Mine doesnt even have the emissions stuff on the V5...
oliwb
posted on 26/10/06 at 07:47 PM |
If it has emissions limits on the V5 (which it should - mine does and its on a 1970 H reg - pinto) then the MOT man must test it to these
figures.....this should be totaly regardless to the reg plate etc as its the engine age....if you needed a CAT to pass SVA you'll need it to
pass MOT....Sorry for being a bit sharp but it annoys me how many ppl don't read it and mess it up! Oli.
PS.
This is also the case for Q-plates....if its on the V5 then MOT man test to that, if it aint its a visible smoke test.....
G.Man
posted on 26/10/06 at 09:01 PM |
PS.
This seems to vary quite a bit, as mine has no emissions figures on the V5 but used a cat for MOT..
Date of first use is shown as 1990 and date of first reg in UK is 2005...
Mine was SVA'd last year...
The information is both inconsistent as are the V5's
G.Man
posted on 26/10/06 at 09:04 PM |
Even the page of the testers manual is inconsistent...
Mine was SVA'd but shows a date of first use as 1990 and is on a G plate, earlier than an S plate...
oliwb
posted on 27/10/06 at 07:20 AM |
G.Man I think you've just gotten lucky! If there are no limits on your v5 it should be a visual smoke test....though the tester may decide to
do either:
- a visual smoke test,
- a G-reg yr related test, or even
- a test relating to the year of your engine.....
I guess you wont know till your first MOT! Oli.
Edit: forgot to say your diagram refers only to the SVA test where they need proof of engine age and emissions are based on this....MOT is different.
It goes buy reg age, or in case of SVA'd cars the limits on the V5. Not these limits don't change....so why doesn't everyone build
a X-flow powered locost then swap it out for a modern bike or car engine??? Oli.
[Edited on 27/10/06 by oliwb]
G.Man
posted on 27/10/06 at 07:56 AM |
I had an MOT 4 months ago in Cyprus...
It passed
alanr
posted on 27/10/06 at 08:07 AM |
I better bring the car over to Cyprus then
A
G.Man
posted on 27/10/06 at 11:12 AM |
A
Trust me on this, it will be less hassle to just fit a cat and get it MOT's in UK...
alanr
posted on 27/10/06 at 11:15 AM |
you're right but I just fancy the idea of coming over to Cyprus
oliwb
posted on 28/10/06 at 09:55 PM |
Sure there must be more 7'ing weather over there than here right now! My car is slowly filling with rain water as unfortunately its sat outside
while the roof of the shed is re-done....sometime b4 xmas....bluh...Oli.
G.Man
posted on 29/10/06 at 07:41 AM |
hehe you wouldnt believe how many thunderstorms we have had recently..
But yes, I am sure its slightly better than uk
