New Topic New Reply
Author: Subject: chassis bracing
caber
posted on 29/10/06 at 10:51 PM Reply With Quote
chassis bracing
I am having problems locating the brace running from the front offside of the engine bay to the scuttle, on my Pinto build there is a big exhaust manifold, steering linkage etc. in the way. I suspect I will have problems on the nearside as well due to carbs and dizzy. Anyone found other ways to brace this area?
TIA
Caber
TheGecko
posted on 29/10/06 at 10:55 PM Reply With Quote
One approach I've seen used a few times is a Y-shaped brace instead of a single tube. Like this:
Engine bay of Mike Laws Locost showing modified 'R' tube
Hope this helps,
Dominic
posted on 29/10/06 at 11:28 PM Reply With Quote
Mine went on the nearside with no problem, it should be lower than your carb and nowhere near the distributor.
JackNco
posted on 30/10/06 at 03:04 AM Reply With Quote
wow i bet that exhaust cover got added after SVA, no offense but ide feel guilty driving round with that on in case i did hit some one.... bye bye calf muscle.
John
Some people are worried about the difference between right and wrong. I'm worried about the difference between wrong and fun.
O'Rourke, P.J. (1989), Holidays in hell. London (Picador)
TheGecko
posted on 30/10/06 at 05:54 AM Reply With Quote
That pic is of an Australian car so no issues with SVA although of course we have our own set of legislative hoops to jump through
D
James
posted on 30/10/06 at 05:47 PM Reply With Quote
TIA
Caber
For a start, you can get round these by changing the alternator and/or routing the steering differently with an extra uj. Also, using a side (bonnet) exit exhaust.
Alternatively you could do what Liam has done with his excellent 'spider' bracing over the top of the engine bay.... see his recent posts over this. Judging by his FEA results it's an excellent way to build the chassis.
Hope that helps,
James
[Edited on 30/10/06 by James]
andrew.carwithen
posted on 30/10/06 at 07:19 PM Reply With Quote
As James says, you can dogleg the lower steering column with an extra uj and spherical bearing to give extra clearance for alternator.
Pic shows Tiger supplied column in situ in my Avon.(bottom of pic) Rescued attachment lower frame welded in situ..jpg
whittlebeast
posted on 1/11/06 at 01:57 AM Reply With Quote
Think triangles. Things at 90 deg have almost no effect and are realy not worth the weight.
AW
New Topic New Reply
