New Topic New Reply
Author: Subject: Ground clearance
ELO
posted on 3/11/06 at 01:50 PM Reply With Quote
Ground clearance
A friend of mine wants to know what the clearance is from the chassis to the ground? N.B. not from the sump but the chassis.
I would go out and measure mine but the chassis is still in the welding stage and any thought of putting wheels on it yet seems a while away!
ed
jos
posted on 3/11/06 at 02:17 PM Reply With Quote
It can vary but mines around 100-120mm
ELO
posted on 3/11/06 at 03:45 PM Reply With Quote
Cheers jos.
Guessed around that type of figure, but good to get conformation.
ed
Confused but excited.
posted on 3/11/06 at 04:03 PM Reply With Quote
I'm aiming for 120mm, because the council in their wisdom have put bloody great sleeping policemen in our road. It's a cul-de-sac for God's sake!
It will vary with engine, engine mounts, wheelsize , tyres(low profile or not) etc.
JackNco
posted on 3/11/06 at 04:56 PM Reply With Quote
Couldnt you try n gt them removed then?
Some people are worried about the difference between right and wrong. I'm worried about the difference between wrong and fun.
O'Rourke, P.J. (1989), Holidays in hell. London (Picador)
StevieB
posted on 3/11/06 at 05:27 PM Reply With Quote
Just remember that if you damage your car on a speed bump, it's the councils fault for making it too big in the first place.
JackNco
posted on 3/11/06 at 05:30 PM Reply With Quote
huh never knew that !
ELO
posted on 3/11/06 at 06:12 PM Reply With Quote
Why on earth put sleeping policepersons down a cul-de-sac!
(Is "cul-de-sac" French for something?)
ed
posted on 3/11/06 at 06:43 PM Reply With Quote
Dead end
posted on 3/11/06 at 10:05 PM Reply With Quote
cul-de-sac translates literally as "bottom of the bag", I believe...
How that gets translated into a one-ended road, I have no idea!
posted on 3/11/06 at 10:22 PM Reply With Quote
i think the cul bit means neck, which effectively means the sign is telling you you are entering a bag
i aim for 4" clearance, but apparently it should be a little nose down, maybe 5" at the back.
[Edited on 3/11/06 by JoelP]
robertst
posted on 4/11/06 at 01:03 PM Reply With Quote
actually "cul" is arse... it means you're at the very end of the bag, you cant go further and the only way out is where you came from i.e: turn around...
Tom
posted on 4/11/06 at 03:51 PM Reply With Quote
ed
There was a petition to have them put in the road that goes through the Bay, to stop idiots clogging through at over 100 mph. In their infinite wisdom, the tossers put them in the side roads. All of which are dead ends!
Go figure.
New Topic New Reply
