New Topic New Reply
Author: Subject: Chassis Steel Type
Afro
posted on 2/6/03 at 09:23 PM Reply With Quote
Chassis Steel Type
Hello people,
As everyone on here seems far more in on the locost gag than me I wonder if any of you can tell me if the material for the chassis is simply mild steel or are slightly more exotic cro-molys like reynolds 531 etc preffered?
I am thinking about racing the beast when shes finished so it needs to be racing legal but neither 'the book' nor the racing regs appear to specify the grade of steel that must be used....
Any help much appreciated...
[Edited on 2/6/03 by Afro]
chrisg
posted on 2/6/03 at 09:41 PM Reply With Quote
It's usually just your common or garden, steel stockholder stuff, nothing to stop you using anything you want really.
Ask in the racing section tho....
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Alan B
posted on 2/6/03 at 10:32 PM Reply With Quote
I've yet to see any widespread availibilty of chromoly tubing in square sections. (never seen any square chromoly at all to be honest....but, I'm not saying it doesn't exist)
As Chris says ordinary mild steel is the usual way.
Sometimes chromoly is used on suspension parts...but always round tube AFAIK
Don't forget chromoly is about the stiffness as mild steel, but of course stronger.....it's big advantage is in PURE spaceframe without bending loads where wall thickness can be reduced....or as a same weight substitute with improved crash strength....(although not always desirable...crumple zones etc.).....
I could go on...but I won't...
HTH
Spyderman
posted on 2/6/03 at 11:58 PM Reply With Quote
Originally posted by Alan B
Snip
HTH
Yes you do, constantly!
Spyderman
Alan B
posted on 3/6/03 at 12:37 PM Reply With Quote
Ah Terry, I see you have noticed my pet peeves and rants........
I know you like it really....
And, I'm only the 7th highest poster on here......must try harder.....
Afro
posted on 4/6/03 at 10:53 AM Reply With Quote
Chassis Steel
Cheers for the pointers, I think mild is the way forward.
Now I have the problem that all of the places I've asked for quotes on steel only do 2mm wall thickness and not 1.6mm on RHS unless I want to go with ERW section which I don't think will be up to the job.....
Any opinions there and useful suppliers??
Alan B
posted on 4/6/03 at 12:11 PM Reply With Quote
I've said this often before......
There is no such thiing as RHS below 2mm....
ERW is EXACTLY the correct material......
Not aimed at you Afro, but this "book" cock up has thrown many people....
Again, there is NO RHS below 2mm.....
kingr
posted on 4/6/03 at 12:33 PM Reply With Quote
I'll give Tiger their due, they call it ERW, so that's one thing that's better than the RC book. It's always slightly confused me the difference between the two, since ERW = Electrical Resistance Welded (or something similar) and RHS = Rectangular Hollow Section, so is it not possible to have ERW RHS? And indeed how is the metal joined in anything other than ERW?
Kingr
Alan B
posted on 4/6/03 at 01:20 PM Reply With Quote
Exactly........RHS is indeed ERW'd....no other practical way to make it...
Just down to specs and terminology...
Steels can be spec'd two ways...by performance (strength, hardness etc) or by chemical composition......even for very similar products...they will often display both, but be guided by one set of specs or the other....
Very confusing I know....
Afro
posted on 5/6/03 at 10:13 AM Reply With Quote
Chassis Steel
Cheers chaps..
This was getting confusing, I had thought that maybe RHS was a drawn section but now realise my errors, in which my dad took immense satisfaction!! (I'm more instrumentation oriented and he's mechanical so he has been telling me most of this from the start!!)... but then office furniture spec steel didn't seem an obvious choice to take me over 100mph
Once again, thanks!!
[Edited on 5/6/03 by Afro]
posted on 5/6/03 at 10:34 AM Reply With Quote
16g RHS.
Our steel stockist will happily supply 1"square 16 gauge, RHS or ERW. You just point to it on the rack and give them the money. They let you call it anything you want because you are the customer. They will go into lengthy technical discussions and tell you anything you want to know about it but eventually it is your choice. They can get thinner wall section tubing on special order but the book steel was easily available from stock when I told them what I wanted. I was surprised how much lighter 16gauge was than the 2mm stuff for apparently little or no sacrifice in strength. The cold drawn round tubing was more of a problem as there were a lot of different specs available.
yours, Pete.
chrisg
posted on 5/6/03 at 06:02 PM Reply With Quote
Not wanting to be pedantic but the stuff we use is SHS rather than RHS "square hollow section" rather than "rectangular Hollow Section".
Chris
Alan B
posted on 5/6/03 at 06:52 PM Reply With Quote
Well it would be if it existed in 16g...
Alan B
posted on 5/6/03 at 06:58 PM Reply With Quote
Pete, it sounds like you have a good supplier....the naming thing doesn't matter until you come across picky jobsworths who will deny all knowledge of a product unless you can name it letter perfect....electrical suppliers in particular used to be like this a lot I recall.......
Metal Hippy
posted on 5/6/03 at 07:01 PM Reply With Quote
They probably just didn't like your face Alan...
Cock off or cock on. You choose.
Alan B
posted on 5/6/03 at 07:34 PM Reply With Quote
Nah...not possible..
It's happened to others I know too....maybe things have changed a bit in 9 years...who knows..
kingr
posted on 6/6/03 at 08:25 AM Reply With Quote
Chris
Well, I'll be equally if not more pedantic right back at you, and point out that squares are merely a specific form of rectangle, so in my view RHS is valid whether it has equal sides or not.
Kingr
posted on 6/6/03 at 09:52 AM Reply With Quote
Common sense suppliers.
Twiggs , Matlock. I said can I have a look through the scrap for some 3mm plate. His reply," We don't keep scrap". I said I meant the pile by the door and he said " Oh, you mean the useable offcuts"..
I like a man with enterprise. Offcuts are sme price as scrap about 35p a kilo.
yours, Pete.
kingr
posted on 6/6/03 at 10:02 AM Reply With Quote
I haven't had much luck with getting scrap bits, there's two places that I can go to for steel, one of which does loads of machined stainless stuff (great if you need a load of swarf or 2cm of stainless bar, not so great other wise) and one that does agricultural stuff (great if you need offcuts of 15mm plate or 150mm x 10mm square section, no so great otherwise).
Kingr
Alan B
posted on 6/6/03 at 02:07 PM Reply With Quote
Chris
Kingr
Not true.....when the sides are equal the designation SHS applies....look at a listing of RHS, there are no square sections...and 2mm is the thinnest wall (did I mention that?...)
Mathematically speaking you are correct of course...
Afro
posted on 6/6/03 at 04:05 PM Reply With Quote
I beg to differ, we have a couple of books at work that list RHS in 25x25 and other 'square' sections. It does form a square and I would have though it to be SHS too but as british steel list it under RHS and they make the stuff who am I to argue... .... .... It's probably purposely done so those not fully educated in the steel stockist code can also be mocked for their misquoting of 150x3mm flatbar as 150x3 plate...DOH!!
Anyway short of asking for 4 equal sided at 1 inch each folded section of 1.6mm thickness welded along one side, I think I've made enough of an unknowledgable idiot of myself with the steel stockists who are probably dying for me to call them again to have the best laugh in weeks once more. Its on order and that is hopefully the end of that..
cheers for the help and good luck to the next mug who ventures their way
Alan B
posted on 6/6/03 at 04:46 PM Reply With Quote
Ah, but they probably mean the generic "rolled hollow section" (also RHS of course) terminology in that case, which includes rectangular, square, and circular hollow sections.....
Damn, soooo confusing..
Certainly my old BSC charts do differentiate between square and rectangular......but hey.....don't suppose it matters really?
I'm sure I must have other things to worry about.......oh yeah, a car to finish.....
Happy steel buying...
chrisg
posted on 6/6/03 at 06:47 PM Reply With Quote
I can't find my steel book waaaaaah!
I was going to post the two different pages - 1 showing SHS, and the other RHS,
It would have been a triumph, I would have bestrode this thread like a collosus!
but as i said I can't find it, you couldn't just take my word for it, could you?
No, didn't think so.
Chris
Alan B
posted on 6/6/03 at 07:18 PM Reply With Quote
My last post on this thread.....much as I'm enjoying it...
http://www.pulmans.co.uk/products_page.htm
This shows the basic materials names and sizes..
HTH
New Topic New Reply
