Alan B
posted on 3/12/06 at 04:02 PM |
My current project
For those who asked...
Some pics of my curved tube mid-engined 3-seater.
Yes, it's a long way from finished.
Yes, curved tubes are structurally bad.
Yes, the workshop is untidy.
Yes, Preston North End will probably slip down the table after the brief stay on top.
Yes, I should have finished the Meerkat first.
Fire away...
New frame 1
New frame 2
[img][/img]
ecosse
posted on 3/12/06 at 04:09 PM |
Looks interesting, I like the way the bottom rails run the length of the chassis and provide the bottom wishbone mounts.
How did you put the curve in the tubes and what are you doing for the body, fiberglass or ally panels, or Atom style?
Alex
DIY Si
posted on 3/12/06 at 04:19 PM |
Are the two top front bars/tubes supposed to have dented ends?
Sun Tzu, The Art of War
Alan B
posted on 3/12/06 at 04:21 PM |
Alex,
Thanks for the comments.
If you look at the thread (my shelved middy project) I have a picture of the tube roller I made..it's basically 3 wheels (rollers) and an old
machine vice.
Bodywork will be absolutely minimal...done enough GRP for one lifetime already..LOL
Alan
Alan B
posted on 3/12/06 at 04:23 PM |
They are not supposed to, no, but it doesn't matter as left them over length (for set up and measuring purposes) to be trimmed later.
Good spot though...
Alan
iank
posted on 3/12/06 at 04:28 PM |
quote: Yes, the workshop is untidy.
<sarcasm> And very cramped </sarcasm>
Looking good.
arrybradbury
posted on 3/12/06 at 04:31 PM |
Looking good! Will that really seat 3 people?? Or is there still more to add??
Alan B
posted on 3/12/06 at 04:45 PM |
Showing 3 seats...
[img][/img]
GavBurns
posted on 3/12/06 at 05:02 PM |
Curved chassis, Minnimal bodywork. It sounds familiar to an Ariel. Is this the inspiration?
I like the idea of 3 seats!
Go BEC you'll never look back (literally)!!
posted on 3/12/06 at 05:14 PM |
i like the front suspension mounts, tidy. The bar bending must've taken some effort to get the precise curve!
Alan B
posted on 3/12/06 at 05:20 PM |
Only partly Ariel inspired.....proir to that I'd seen a few sandrails (buggies) with big radius curved tube construction....also the Mac F1
seating arrangement comes into play.....so quite a mix really and hopefully a few new things to throw in......
Alan
Alan B
posted on 3/12/06 at 05:25 PM |
Cheers Joel,
Actually the tube rolling turned out easy...a few tricks, but actually easier than regular small rad. bending.
Alan
Wadders
posted on 3/12/06 at 05:29 PM |
Looks good Alan. Can i ask do you suffer from severe insomnia, there must be some explanation of how you manage to fit so much into 24hrs
ecosse
posted on 3/12/06 at 05:43 PM |
machine vice.
Alan
The tube bender looks great (don't know how I managed to miss that post) if you don't mind me asking, do you push the tube through the
mandrels somehow, or do you bend a section at a time and hand feed it?
And is the bending pressure all done via the vice?
Although the end result looks great however you do it
Alex
sgraber
posted on 3/12/06 at 06:44 PM |
That's gonna be really, really neat!
What will you be using for uprights? Custom?
I am in need of some large radius tube bending. Will you make plans available for your machine? Or be kind enough to impart the part numbers and
general assembly info?
Thank you!
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
akrallysport
posted on 3/12/06 at 06:55 PM |
Steve,
Alan has posted a pic of his bending setup in the following topic... http://www.locostbuilders.co.uk/viewthread.php?tid=56045 (about 2/3 of
the way down). Just to give you some idea of what it entails.
StevieB
posted on 3/12/06 at 07:17 PM |
Looks good.
But you're right about the messy workshop - I don't know how you manage to work in such untidy conditions
andyd
posted on 3/12/06 at 07:52 PM |
Alan,
Are those front suspension mounts just welded in between the tubes or does the tube go through the brackets?
Alan B
posted on 3/12/06 at 11:52 PM |
Good feedback, good questions.
Some answers:
Tube roller construction:
One old or cheap machine vice
Two welded brackets that fasten to the vice in place of the jaws.
Three Rollers which are vee wheels straight from the McMaster Carr catalog (around $14 each IIRC)
One handle mounted on the single wheel.
Tube roller operation and notes:
Place the tube in rollers and tighten to a very slight grip...move tube to one end (you can't reach all of it so you must design a 6" (or
so) straight length at each of your part or make it longer and trim the ends.
Then tighten up the vice a little and wind the tube with the handle (mangle style) to the other end...then tighten the vice a liitle and wind it
back....and so until you have the radius you need.
I machined the wheel to try and match the actual tube radius this seems more important the more wall thickness to OD ratio of the tube you roll
reduces. The result of vee only or bad matching on relatively thin tube is marking and distortion especially on the inside (logical I guess)....e.g.
1" x 16g rolled easily in vees with minimum distortion whereas the 1.5 x 16g benefitted from a matching radius.
Bottom line..radiussed wheels do a better job, but aren't always essential.
Uprights:
Yes, custom fabbed. using the bolt-in Chevy Cavallier hub unit all round.
Front suspension mounts:
Yes the tube goes right through them...so it's vital to remember to slip them on during assembly....Can't take credit for the idea
though..it's an old TVR trick.
Insomnia:
Eh?..what?..ZZZZZZZZZZZZZZ
ecosse
posted on 4/12/06 at 10:34 AM |
Thanks for the tube roller details, bloody brilliant IMHO
Is the suspension geometry and design your own or does it have the traditional locost basis?
And last question (you will be wishing you hadn't asked ) do you have any intentions to produce these or sell plans or anything?
I look forward to watching your progress with it.
Alex
Syd Bridge
posted on 4/12/06 at 11:10 AM |
Ah, p155 on those who want to knock you Alan!
An excellent effort, even if the suspension geometry is not what I would use.
The smart ones would have spotted, and be very envious of that Miller TIG machine in the background.
Syd.
sgraber
posted on 4/12/06 at 01:12 PM |
Thanks for the info on the bender. I agree, it's simple beyond belief and brilliant in concept. It must have been done before! (Because
nothing is original, ever)
Will the Meerkat body fit on that chassis? If not, what are the overall dimensions? Track, wheelbase?
Which Honda powerplant is that? Is it the hybrid?
Steve Graber
Alan B
posted on 4/12/06 at 02:02 PM |
Alex
Thanks Alex,
Yes, the front suspension is traditional unequal length wishbones (locostish).
Yes, the plan is to definitely do something with finished product...but there is a long way to go.
Alan
Alan B
posted on 4/12/06 at 02:04 PM |
Syd.
Hi Syd,
What would you do geometry wise?
Good spot with the Miller...
Alan
Alan B
posted on 4/12/06 at 02:07 PM |
Hi Steve,
The three roller method is pretty much standard practice...adapting the idea to be cheap was the only clever bit..
The Meerkat body probably would fit, although I couldn't say for sure without some checking.
The engine in the background is the Honda I-VTEC......gotta love E-bay..LOL
