goodall
posted on 23/12/06 at 08:49 PM |
whats different between a lotus 6 and a lotus 7?
hillbillyracer
posted on 23/12/06 at 08:53 PM |
1
cossiebri
posted on 23/12/06 at 09:02 PM |
If it doesn't fit MODIFY it!!
Cheers BriF
goodall
posted on 23/12/06 at 09:06 PM |
ok i didn't mean the maths problem.
that would have been stated "whats the difference between 6 loci and 7 loci" if my latin is right and also don't confuse this with
the maths systerm called loci
also the right answer would be -1
none the less it did make me laugh
[Edited on 23/12/06 by goodall]
hillbillyracer
posted on 23/12/06 at 09:13 PM |
Sorry, it had to be done! I've no idea really.
caber
posted on 23/12/06 at 09:15 PM |
IRR Lotus 6 has a beam front axle and is based on a Ford chassis It has a rounder nose check
herelinky
Caber
goodall
posted on 23/12/06 at 09:22 PM |
the frame looks alot lighter in those pics
iank
posted on 23/12/06 at 09:32 PM |
6 had all aluminium bodywork IIRC.
Another cheap answer would be about £10k
gator
posted on 24/12/06 at 03:36 AM |
IRR the front axle was a swing axle, based on the Ford (Popular?) beam axle.
posted on 24/12/06 at 09:22 AM |
100% correct
Macbeast
posted on 24/12/06 at 09:24 AM |
Caber, I'm pretty sure the Six had a space-frame chassis to Chapman design, made by Progress Engineering. The big difference six v seven is the
front axle which on the Six is transverse cart spring, cut and pivoted in the middle.
[Edited on 24/12/06 by Macbeast]
goodall
posted on 24/12/06 at 12:06 PM |
so really the difference is very small, its just a front surspension change
so i guess that makes any car with irs the same as what a lotus 8 would have been
iank
posted on 24/12/06 at 07:29 PM |
Lotus 8 is a streamlined car with a body by Frank Costin.
http://www.ultimatecarpage.com/frame.php?file=car.php&carnum=1496
goodall
posted on 24/12/06 at 10:15 PM |
ok then so its a 6C cause the 7 should have been the 6B
cs3tcr
posted on 25/12/06 at 08:41 PM |
The 6 had a split front axle with coil springs, the chassis was narrower than the Sevens, was a space frame, typically powered by a Ford side valve
engine, or an MG XPAG, body was all alloy, was Lotus first real production car.
t.j.
posted on 26/12/06 at 05:55 PM |
let's post a picture:
So maybe get this idea to build a six instead of a 7...........
[Edited on 26/12/06 by t.j.]
