New Topic New Reply
Author: Subject: Supplier of metal off cuts??
garage19
posted on 22/2/07 at 09:15 AM Reply With Quote
I'm sure there were a couple of companies supplying off cuts of metals for hobby engineers like ourselves but can't find them anywhere. I have tried a few Google searches with no success.
Does anyone have a link/contact?
JAG
posted on 22/2/07 at 09:18 AM Reply With Quote
Search for your local Metal Supermarket. They're not the cheapest but will provide small amounts and cut sheets to size for you.
Check out this LIST
[Edited on 22/2/07 by JAG]
Justin
smart51
posted on 22/2/07 at 09:27 AM Reply With Quote
I second metal supermarkets. They will cut however little you want from their warehouse full of stock.
posted on 22/2/07 at 10:28 AM Reply With Quote
Metal supermarket are pretty good. If the off-cuts are really small they sometimes don't charge
Otherwise the usual Ebay search finds a fair bit of metal stock...
iank
posted on 22/2/07 at 01:38 PM Reply With Quote
If you can get into Cambridge check out MacKays (by the grafton centre)
http://www.mackay.co.uk/
They have a metal stockholder section out back by the car park. Good for small amounts and they cut while you wait.
The tool shop sells decent brands so is very good if not cheap
Anonymous
jollygreengiant
posted on 22/2/07 at 02:31 PM Reply With Quote
Bilsons in Kettering. all the metal bit I needed to finish of the build (engine mounts & column extension £3 and then some left over to do it again)
Just call in to your Local stockist & ask about off cuts
posted on 22/2/07 at 03:13 PM Reply With Quote
Make sure that you take a well-stocked wallet - their metal is expensive! I must admit to buying stuff from there purely for convenience (i.e. I was in the area). They also sell chunky sizes in ali & brass, which are hard to find (or expensive to post) from on-line sources.
Also, don't go there if you're in a hurry - watching some of the staff in the metal salesroom is like watching poetry in motion (i.e. how slow can they really go without falling over, or going to sleep).
The nearest Metal Supermarket is in north London - great place if you're in the area, or you want enough stuff to warrant the journey.
iank
posted on 22/2/07 at 03:21 PM Reply With Quote
Think they probably charge a lot per cut. I bought 2x2m lengths of 25x25x1.6 and it came to £10 which didn't seem too bad for a small quantity premium.
All done in 10mins during a lunchbreak for me.
Anonymous
welderman
posted on 22/2/07 at 03:37 PM Reply With Quote
I can supply some stuff, but all depends on what your after.
Thank's, Joe
I don't stalk people
New Topic New Reply
