andrews_45
posted on 25/2/07 at 06:41 PM |
Can somebody pls tell me the thread size?
This is a standard book setup IIRC it is a transit track rod end ball joint. Can somebody tell me what size thread it is that tightens the ball joint
onto the upright?
Ta
mad4x4
posted on 25/2/07 at 06:45 PM |
Thought you were on about the other one.
not sure i't not Metric from memory
[Edited on 25/202/07 by mad4x4]
Scot's do it better in Kilts.
stevec
posted on 25/2/07 at 06:53 PM |
M12 1.75 methinks.
Steve.
indykid
posted on 25/2/07 at 10:25 PM |
depends on the manufacturer of the ball joint. they all use different threads.
tom
Chippy
posted on 25/2/07 at 11:47 PM |
M12 on mine also. Ray
andrews_45
posted on 26/2/07 at 04:57 PM |
It is the same thread as on the ford Ghia wheel nuts
flak monkey
posted on 26/2/07 at 05:13 PM |
M12 x 1.5 in that case (ford wheel nut thread). Which is one of the iso fine versions of the M12 thread.
Std pitch for M12 is 1.75 and std M12 fine is 1.25.
Sera
http://www.motosera.com
andrews_45
posted on 26/2/07 at 05:14 PM |
Excellent, many thanks chaps once more!
