posted on 28/2/07 at 02:40 PM |
all your MOT questions answered..
... well, some of them
interesting one about there being no distance limit to drive to an MOT.
bartonp
posted on 28/2/07 at 03:21 PM |
What about the guy who was getting cross because the MOT station wouldn't accept his Fiat Uno sills being 'repaired' with chemical
weld??
smart51
posted on 28/2/07 at 03:41 PM |
"The MOT regulations say nothing about a vehicle having a catalytic converter. They merely set emission levels which have to be achieved if the
vehicle is first used after a specific year. "
Does a car HAVE to have a cat for SVA? I know it has to meet the emissions limits but does it actually have to have a cat in the exhaust?
DarrenW
posted on 28/2/07 at 03:49 PM |
I believe that ref emissions they are only concerned if it passes or not rather than if it has a cat or not. The only issue / link comes if the only
way to pass the test is by having the cat fitted. Spo in theory if it passes without a CAT then nothing to worry about imho.
russbost
posted on 28/2/07 at 06:02 PM |
Theoretically you could pass without a CAT, in practice highly unlikely.
posted on 1/3/07 at 09:08 AM |
if it were that easy, manufacturer's wold not go to the expense of developing and fitting CATs.... so extremely very unlikely.... (I could be
wrong but ....)
smart51
posted on 1/3/07 at 09:42 AM |
wrong but ....)
Manufacturers fit the cheapest cat possible to save money. Some engines are so clean that very lightly loaded cats are fitted. Some older engines
need heavily loaded cats to clean up the smog.
My R1 engine at SVA was fitted with a cat that didn't work. Adjusting lambda to the correct level was easy and the CO was very low. It was
only the HC that was too high. A new cat sorted that out. An 8 year old carbed R1 is probably not the cleanest of lumps available. Newer emmissions
frienly engines may well meet cat emissions levels without a cat when new but like all things, they age.
I'm quite sure that if an engine could be tuned in software (which is free per car sold) or with cost neutal hardware changes to meet cat
emissions standards with the cheapest cat availale, many would do just that to save money on cats.
