Author: Subject: Styrofoam or similar?
Howlor
posted on 12/3/07 at 02:24 PM Reply With Quote
Afternoon one and all,
I want to hand craft a body plug and would like to know where is best to buy the foam from that can be carved and shaped?
Thanks,
Confused but excited.
posted on 12/3/07 at 03:01 PM Reply With Quote
Polyurethane foam sheets from a builders merchants seems to work quite well and you can buy squirty tins of the same stuff. Downside is it make one hell of a mess. Upside, you can shape it easily with sandpaper.
smart51
posted on 12/3/07 at 03:29 PM Reply With Quote
Polyurethane foam is easily sandable and is polyester resistant. Get it from Scot Bader shops in sheets upto 8x4 x 4" or as a 2 part liquid.
B&Q sell polystyrene in upto 8x4 sheets upto 4" or 6" thick. You can't use polyester on it because the styrene solvent will desolve the polystyrene. Epoxy resin is good though.
RazMan
posted on 12/3/07 at 04:00 PM Reply With Quote
I have heard that the stuff that florists use is pretty good - can't think of the name at the moment but it is green and comes in block form. You can practically build the shape like lego bricks and then shape it with a sharp bread knife.
*edit* It's called OASIS
[Edited on 12-3-07 by RazMan]
Raz
pewe
posted on 12/3/07 at 04:03 PM Reply With Quote
Sheffield Insulations (branches throught the country) used to do modelling expanded polystyrene. This is much denser than ordinary material and can be planed, sanded and shaped without crumbling - not cheap from memory but ideal for your application. Cheers, Pewe
Nick Skidmore
posted on 12/3/07 at 04:55 PM Reply With Quote
Plywood / MDF / hardboard 'bulkheads' at 2" spacing filled in with 'browning' (gyproc product) for basic shape then polyfiller or P38 to finish off.
Very cheap compared to other methods but very heavy.
SaveTheDodo
posted on 12/3/07 at 05:24 PM Reply With Quote
Try Flints Theatrical Chandlers for the 2 part foam. Fairly reasonable if I remember.
Andrew
P.S. Have you got a dog to help you style it in best Peter Wheeler fashion??
Andrew
jacko
posted on 12/3/07 at 06:14 PM Reply With Quote
Hi Howlor i think there is a firm in howden that make or made polyurethane sheet it may be worth a serch i think the firm was near the iron bridge on the goole road
Sonic may know were it is
Jacko
Gaz 1977
posted on 12/3/07 at 06:29 PM Reply With Quote
blue foam
i would use the blue foam that is used in wall insulation. It comes in 2 inch sheets and can be laminated with PVA or Araldite. It sand to a really good finish if you are carefull.
GAZ
Howlor
posted on 12/3/07 at 08:29 PM Reply With Quote
Plenty to go at here thanks. Exactly the leads I was looking for.
Thanks,
sonic
posted on 12/3/07 at 10:05 PM Reply With Quote
Vensil resil ltd
Jablite nr Boothferry bridge
