New Topic New Reply
Author: Subject: Transmission tunnel
willemv
posted on 26/3/07 at 02:08 PM Reply With Quote
Transmission tunnel
What transmission tunnel size gives the best options on engine/gearbox installations. Cortina diff (100 mm wider than book)
mookaloid
posted on 26/3/07 at 02:26 PM Reply With Quote
I believe you generally need to select your engine/gearbox combination and then build round it to make sure it fits.
What do you have available where you are?
willemv
posted on 26/3/07 at 02:40 PM Reply With Quote
South africa
I have been thinking 20V toyota with a 21R gearbox. The t50 being difficult to get.
The other option is the 16V turbo motor onto same gearbox.
The engine gearbox needs an adapter
I thought a generic size that would allow a wide range of known combinations might be a better solution.
[Edited on 26/3/07 by willemv]
posted on 26/3/07 at 05:36 PM Reply With Quote
the bigger gearboxes will eat into your pedal space, best to pick one and leave it what it needs, so keeping the max space for yourself.
New Topic New Reply
