New Topic New Reply
Author: Subject: Why do it the locost way
sammy
posted on 16/4/07 at 02:06 PM Reply With Quote
Anyone ever have moments when they think "why didn't I just buy a flippin' kit?".
Sunday I started making the suspension brackets out of square tube. When the first one was finished and I put a bolt and a bush in it, I was dead chuffed! After finishing the 10th bracket I was thinking... (and I still have more to do)
Build diaries...
nib1980
posted on 16/4/07 at 02:20 PM Reply With Quote
your missing an option of all of the above
stevec
posted on 16/4/07 at 02:29 PM Reply With Quote
I admire everyone who does it all themselves.
But once you have made 1 bracket you now have the Tshirt, You can buy a set of them very locost. Make 1 and buy the rest,
Steve.
TimC
posted on 16/4/07 at 02:41 PM Reply With Quote
I don't think I'd ever build my own chassis although next time (if there is a next time) I might be tempted to go a bit more basic and do a bit more myself.
The MNR I bought is definately one of the easier options.
bob
posted on 16/4/07 at 02:46 PM Reply With Quote
I bought the chassis bones and FB but everything else was fashioned with a hammer because i'm as tight as a ducks ....
sammy
posted on 16/4/07 at 03:05 PM Reply With Quote
Yes that should have been an option.
I'm doing it myself partly for the satisfaction of making most of the bits, partly to get what I want (wider chassis with a RV8), partly because I just seem to always want to things the hard way (I must be a masochist), and because I didn't want to pay for a kit (yes I am tight as a ducks @rse!).
Build diaries...
bob
posted on 16/4/07 at 03:11 PM Reply With Quote
I worked out that paying for the chassis and body are the cheaper part of the operation,the wheels shocks and seats plus the dash can reach the total of the initial kit outlay.
carlgeldard
posted on 16/4/07 at 03:30 PM Reply With Quote
Does that mean there is a 50/50 split between kit builders and locost builders
Just watch the results change now I've said that!!!!!!!
big_wasa
posted on 16/4/07 at 03:40 PM Reply With Quote
Yes have them often.
Made all my brackets out of 50mm box section.
DavidM
posted on 16/4/07 at 04:02 PM Reply With Quote
I clicked "for the satisfaction of building it myself", but those that know me would say I should have picked the "tight as a ducks arse" option.
Mind you, you can't argue with being on the road for less than the cost of most basic kits, and I only had to give up 6 years of my life to build it.
I'm still thinking about what to build next.
rav
posted on 16/4/07 at 04:27 PM Reply With Quote
made the brackets out of box section?
You had it easy!!!
I couldn't afford box section and had to bend offcuts of strip in vice using my BARE HANDS!
Call yourself a locoster? Ha!
wilkingj
posted on 16/4/07 at 05:07 PM Reply With Quote
Bought a kit, as I couldnt weld well enough then. I'm not much better now, but trust my work a bit more!.
I didnt want to get on the road and kill myself, or worse still some one else or a kiddy, just because my welding skills are not up to scratch.
Safety was the No1 order of the day in my books and still is.
Best Regards
Geoff
http://www.v8viento.co.uk
t.j.
posted on 16/4/07 at 05:15 PM Reply With Quote
I'm living in Europe, kits are too expensive, and as bad as i build
Now i can build it slowly and me wife doesn't notice that is not that locost after al
blakep82
posted on 16/4/07 at 05:31 PM Reply With Quote
i'm doing mine to have something unique on the road.
________________________
scoop
posted on 16/4/07 at 05:50 PM Reply With Quote
Made my chassis but never again.
If i make another one it will be a kit. Less than a year to build instead of three!!
Miek
posted on 16/4/07 at 05:58 PM Reply With Quote
Anyone using a small garage with no power supply?
I'm using a generator and a small welder. That's dedication for you.
dnmalc
posted on 16/4/07 at 06:21 PM Reply With Quote
Didn't have the cash for a kit in one go. I can loose the cost without SWMBO noticing and also I enjoy the challenge. I think i must be touched or something.
UncleFista
posted on 16/4/07 at 07:29 PM Reply With Quote
No, but we built ours with a power supply, but no garage
Tony Bond / UncleFista
907
posted on 16/4/07 at 07:31 PM Reply With Quote
Why make it yourself?
If you need to ask this question then you probably wouldn't understand the answer.
Paul G
ELO
posted on 16/4/07 at 08:21 PM Reply With Quote
You had it easy!!!
You used a vice!
Pah, I had to first make the steel myself then bend it into shape using my own teeth!
ed
davie h
posted on 17/4/07 at 12:49 AM Reply With Quote
i cant afford a kit but can buy bits n bobs as i go and the plus side is that i get the satisfaction of doing it myself
C10CoryM
posted on 17/4/07 at 12:51 AM Reply With Quote
How about: as a design/fabrication lesson?
Wanted to learn with something cheap before doing something more costly and screwing it up. Kind of sounds like my love life actually.....
"Our watchword evermore shall be: The Maple Leaf Forever!"
New Topic New Reply
