New Topic New Reply
Author: Subject: can fuel tank be part of chassis?
posted on 11/5/07 at 08:43 AM Reply With Quote
just wondering, if one were to make a space frame then take some pieces of steel and weld over a box sectin of chassis with some end bits to make it air tight, could that be use to store petrol?
balidey
posted on 11/5/07 at 08:45 AM Reply With Quote
I don't like the sound of that, any chassis flex or 'accident' will probably split the joins. But how about fitting a bag tank in the cavity?
3GEComponents
posted on 11/5/07 at 09:45 AM Reply With Quote
That's how the GT40's tanks were done
posted on 11/5/07 at 10:32 AM Reply With Quote
As ^^^^ said, should be no different than a separatey mounted tank.
I did consider the flexing but it would be hanging off the main chassis, like on GT40 so shouldn;t have any driving force (engine/suspension) going through those memberm at mose supporting some body work.
Mark Allanson
posted on 11/5/07 at 11:36 AM Reply With Quote
Sounds like the safest option to me, you could use the internal triangulation as an unusual swirl pot type device.
scudracer
posted on 11/5/07 at 12:06 PM Reply With Quote
Hmmm, IMHO even if you do something like what Buell Motorcycles have done, putting fuel in the side sections of the frame, there wouldn't be enough for a full sized automobile. Also, flexing, safety, etc. ... to many negatives to pursue this idea, to me.
Shameless-ad-supported-blog-that-belongs-to-my-friend plug - http://www.sevenbuilder.com & http://www.bikervoodoo.com
drlloyd
posted on 11/5/07 at 12:16 PM Reply With Quote
Interesting thought, if I were to pursue the idea I would also consider the possibility of corrosion and hence fuel contamination. Would this not be easier to limit in a basic fuel tank?
posted on 11/5/07 at 12:47 PM Reply With Quote
No more possibility of corrosion that a fabricated steel tank IMO. I don't think the OP wants to fill up chassis tubes with petrol, but simply integrate a conventional steel fuel tank into the frame.
iank
posted on 11/5/07 at 12:59 PM Reply With Quote
If you plan to do it and SVA it I'd suggest calling your local station to see what they say.
It would be a bitch to change once constructed.
Anonymous
New Topic New Reply
