New Topic New Reply
Author: Subject: My modified dials :D
novacaine
posted on 29/5/07 at 11:42 AM Reply With Quote
a while back "Rayward" gave me a set of Lexus dials, which i thought looked pretty good but i didnt like the "lexus" badge on them so i set about modifying them, ive changed the backlighting from orange to blue and in the process of pulling them appart this happend to them
Badge shamelessly ripped off a google image search so if its owner objects to me using it i will of course remove it
what do you all reckon?
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
omega 24 v6
posted on 29/5/07 at 11:49 AM Reply With Quote
Very nice.
p.s. where does your sig come from.
"and as we wind on down the road, our shadows taller than our souls, there walks a lady we all know, who shines white light and wants to show"
chockymonster
posted on 29/5/07 at 11:53 AM Reply With Quote
Originally posted by omega 24 v6
Very nice.
Stairway to Heaven, Led Zep.
flak monkey
posted on 29/5/07 at 11:54 AM Reply With Quote
Stairway to heaven
Bollocks too slow...!
[Edited on 29/5/07 by flak monkey]
Sera
http://www.motosera.com
omega 24 v6
posted on 29/5/07 at 11:56 AM Reply With Quote
Thanks twas puzzling me as I knew it from somewhere in my dim and distant past
PeterW
posted on 29/5/07 at 12:46 PM Reply With Quote
Matt
Matt
They look really good - one question tho - how are you going to drive them in terms of sensors and lcd etc, as surely they need the ECU from the Lexus...?
Pete
posted on 29/5/07 at 12:58 PM Reply With Quote
did you have to remove the pointer to get the white label on?
If it is a mechanical speedo, you may have messed up the calibration if you have reffited needle in not exaclty the smae place. - not sure about this - but the needle is held in place by a coil spring and you may have moved its resting place.
if you know how many mphs you are fast.slow, you can reposition the needle.
rayward
posted on 29/5/07 at 01:07 PM Reply With Quote
the speedo is sensor driven, from magnets or similar
Ray
Guinness
posted on 29/5/07 at 02:46 PM Reply With Quote
Nice, but I would have removed the MPG gauge. It'll only make you smile / cry.
Plus, I don't think the mpg gauge goes low enough at 0!
Mike
New Topic New Reply
