TimC
posted on 20/8/07 at 07:09 AM |
Sierra diff backplate leaking.
Morning all.
I bolted the backplate onto my diff and filled with oil yesterday. I'd read somewhere that you shouldn't use any form of gasket so I just
checked that the surfaces were square and bolted the thing on. Unfortunately I've got a small amount of 'seepage.' It's
going to be a pain to empty and re-do but can anyone offer advice on what to do to make sure that the seal is good 2nd time around?
I've searched but can't find the answer I need.
Thanks in advance.
TC
speedyxjs
posted on 20/8/07 at 07:26 AM |
When i first rebuilt an engine (1.5hp lawnmower ) it had no gasket on the sump so i put a small amount of oil round the edges and that worked really
well.
Might work on your diff but it means having to take it out again
The Great Fandango
posted on 20/8/07 at 08:06 AM |
Most diffs I have owned (already in the kit cars I bought) had had some kind of gasket between the main body and the back casing.
I believe the stuff on mine at present is that sikoflex stuff people use to bond cycle wings on.
He Who Dies With The Most Toys Dies The Happiest
mookaloid
posted on 20/8/07 at 08:30 AM |
I used a light smear of instant gasket - works a treat
Mark
I'd avoid Sikaflex (or other PU sealants) as they don't fare too well with oil and pterol. I'd either get a sheet of gasket paper
and make one to fit or run a bead of instant gasket around the edge before re-fitting the back plate. There shouldn't be any pressure in side
the diff casing, but the oil will get pretty warm/thin.
Never actually looked before, but the Haynes manual has a distinct lack of info on the diff. It describes replacing the pinion and driveshaft oil
seals and then says any other repairs/overhaul work should be entrusted toa Ford dealer!
posted on 20/8/07 at 08:32 AM |
Better idea, don't take it off, why would you want to? Keep it simple.![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
worX
posted on 20/8/07 at 09:46 AM |
EBAY LINK
aerobrick
posted on 20/8/07 at 09:48 AM |
Having refurbed a few diffs now and the Haynes manual is lacking but after working things out the back plates do have a gasket sealant/jointing
compound on them,you may have seen a very light brown film on both surfaces when you took it apart, this needs to be scraped off then wiped clean.
As stated use a good silcone sealant just smear one surface putting the sealant around both sides of the bolt holes bolt up job done.
