Author: Subject: Sierra ignition connector thingy
gingerpaule
posted on 18/9/07 at 02:10 PM Reply With Quote
Hi all.
I'm just fitting my alarm / immobiliser system and it needs to control the ignition circuit to work correctly. I realised the other day that the neatest way to do this would be to unplug the ignition key and plug the ignition control into it instead. To do that I need the connector that is on the key on the steering column. I want to keep mine on so that I can plug the key in again if I'm have a problem with the electronics (once the immobilser has also been disabled).
So, does anyone have one of these connectors? I've put a picture below of what I'm talking about. Thanks in advance!
[Edited on 18/9/07 by gingerpaule]
