New Topic New Reply
Author: Subject: Big en bearing and Main bearing
Micael
posted on 5/10/07 at 04:05 PM Reply With Quote
Hi guys,
What's the difference between main bearings and Big end bearings?
I have to buy some new bearing to my Zetec and on ebay some sells big end bearings and other sells main bearing.
I need all "bottom" bearings (crank and conrods).
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23 2009
mookaloid
posted on 5/10/07 at 04:07 PM Reply With Quote
Mains are the Crank bearings, Big ends are the bearings in the conrods where they attach to the crank.
HTH
Mark
Micael
posted on 5/10/07 at 04:11 PM Reply With Quote
Thanks,
So will need both sets then.
Micael Moose Åman
ash_hammond
posted on 5/10/07 at 04:12 PM Reply With Quote
Be careful tho there are different sized bearings. Best thing to do if your not sure what size they are is take them to ur local engine builder and he will be able to supply you with the correct size. Fitting the wrong size bearings can create all sorts or problems even engine death.
.: www.mac1motorsports.co.uk | www.m1moc.com :.
ash_hammond
posted on 5/10/07 at 04:15 PM Reply With Quote
If you require all bottom end bearings then you so need big end and main bearings
big end bearings is the place were the con-rod connects to the crank.
Main bearings are what the crank sits in and turns.
Micael
posted on 5/10/07 at 04:17 PM Reply With Quote
I haven't removed the crank yet, but this is how the pistons and head looks like
[Edited on 5/10/07 by Micael]
Micael Moose Åman
Micael
posted on 5/10/07 at 04:18 PM Reply With Quote
sorry, forgot the picture
Micael Moose Åman
Micael
posted on 5/10/07 at 04:19 PM Reply With Quote
And the head
Micael Moose Åman
Paul TigerB6
posted on 5/10/07 at 05:07 PM Reply With Quote
Until you get the crank out and check for any signs of wear that may require machining, you wont know what size bearings you will need. The crank may even have been machined previously so requiring oversized (or is that undersized) bearings.
* edited after realising you already stated the crank was still not removed
[Edited on 5/10/07 by Paul TigerB6]
Micael
posted on 5/10/07 at 07:04 PM Reply With Quote
I plan to remove the crank tomorrow.
I suspect that it is a big end bearing failure that has cause the piston hitting the head.
Micael Moose Åman
pewe
posted on 5/10/07 at 08:02 PM Reply With Quote
Whilst you are at it check for end float on the crankshaft. That's movement of the crank backwards and forwards along the block. You should be able to check this with feeler guages and find out the acceptable tolerance from either the workshop manual or google it. Don't ignore it if it's too much as it can affect the ability of the crankshaft oil seals to seal as well as wear on connecting components.
You should buy a bottom end gasket set which should include these seals. New shims to control end-float from your dealer or engine component supplier.
Finally make sure you know where they all go when you take the crank out as they are split (like half moons) and should go back in as pairs, in the same position and facing the same way as originally.
Cheers, Pewe
posted on 11/10/07 at 11:12 AM Reply With Quote
In which case you will be lucky if you can just put new bearings in. It's quite likely the crank will need to be reground if the bearing has gone badly enough to let the pistons hit the head.
New Topic New Reply
