whitestu
posted on 10/10/07 at 02:32 PM |
Zetec flywheel bolts
I'm hoping to trial fit the Zetec tonight so will need to get the flywheel and clutch on.
Does anyone know what the flywheel to crank bolts on a Zetec blacktop should be torqued up to?
Stu
nathanharris1987
posted on 10/10/07 at 02:41 PM |
f-tight?
whitestu
posted on 10/10/07 at 02:54 PM |
I knew someone would say that!
GazzaP
posted on 10/10/07 at 03:20 PM |
crossflow ones are 68nm-76nm
www.gmpmotorsport.co.uk
Mole
posted on 10/10/07 at 05:28 PM |
112 nm (83 lbft) according to Haynes
THE BEAR
posted on 11/10/07 at 07:35 AM |
DEPENDS WHAT ENGINE YOU GOT 1.8 OR 2.0 LT THE 2LT IS 107NM AS I JUST DONE MINE
whitestu
posted on 11/10/07 at 07:45 AM |
Mine is a 1.8 Blacktop.
I'll go for 83lb/ft.
Stu
