TimC
posted on 24/10/07 at 09:21 PM |
Stopping Yamaha Bits Rusting.
My car's barely been out of my warm garage 5 minutes and look at it!
Any ideas?
bigrich
posted on 24/10/07 at 09:34 PM |
unfortunately,that will happen whilst its outside being built.
try libraley coating with wd40 to keep the moisture from any bare metal component
Coose
posted on 24/10/07 at 09:41 PM |
Where have you been in that? Driving through the sea?
Spin 'er off Well...
RazMan
posted on 24/10/07 at 10:02 PM |
A lick of Smoothrite will stop the rust getting any worse
Raz
Bluemoon
posted on 25/10/07 at 07:44 AM |
My way of dealing with this:
Waxoyl saturated rag wiped over parts if you don't intend to paint the part... It will polish with a clean ish rag once "set" if you
don't like waxoyled look...
Dan
[Edited on 25/10/07 by Bluemoon]
TimC
posted on 25/10/07 at 07:50 AM |
Must be salty air in Cheshire I guess.
jambojeef
posted on 25/10/07 at 01:04 PM |
I stumbled upon this stuff which doesnt leave a nasty oily coating on everything and I can highly reccommend it!
Works really well for giving things a nice shine and keeping out the water and surface rust - not on your braking surfaces though since its PTFE
based.
http://www.muc-off.com/motorcyclebikespray.html
Geoff
Ares
posted on 25/10/07 at 01:11 PM |
Fact of life bare metal will rust or corrode.
As soon as it goes outside whether being built or driven it'll rust.
I would have painted them before fitting.
Lack of will power has caused more failure than lack of intelligence or ability.
There's hope yet then !
welderman
posted on 25/10/07 at 08:20 PM |
I agree with the above, as i work maily in stainless steel, we do however work in other materials such as mild steel, if the jobs not ready to start
asap then i get one of the muppetts here to paint them in a primer so as there is no surface rust, thus stopping the surface to become rusty.
When building my car, once the parts were stripped off the sierra, they were cleaned up then primed up and left until needed.
Thank's, Joe
I don't stalk people
TimC
posted on 26/10/07 at 07:21 AM |
Everything else is painted (just about.) As you can see, I painted the prop adapter as I know how easily these go. I didn't expect the yam
bits to be mild!
Ares
posted on 26/10/07 at 02:53 PM |
The output shaft from the motor isn't mild steel !
cossey
posted on 26/10/07 at 03:26 PM |
but it is low cr alloy steel so will rust like mild
welderman
posted on 29/10/07 at 06:21 PM |
yep so when you get your bike new, its covered normally in oil/grease so thats why it dont rust.
Thank's, Joe
