New Topic New Reply
Author: Subject: Clearance?
chrisg
posted on 26/10/07 at 06:36 PM Reply With Quote
Clearance?
Calling all lathe experts!
I'm making two circular parts that fit one inside the other, the inner part is 40mm outside diameter.
How much bigger does the outer part need to be internally so that I get a good sliding fit, without sideways movement.
Millimeters (well fractions of) please, I don't do imperial
Ta.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
posted on 26/10/07 at 06:38 PM Reply With Quote
A couple of thou? I don't do metric
Wadders
posted on 26/10/07 at 06:47 PM Reply With Quote
1 thou = 0.001" = 0.0254 mm
Al
Mansfield
posted on 26/10/07 at 06:48 PM Reply With Quote
You want a 40 H7 hole I think.
Shaft will be 40 g6.
ROYMECH is good for this sort of thing.
40.000 - 40.025 hole
39.991- 39.975 shaft
This on the 'hole' based system of tolerancing, the hole is generally size to plus. Ground bar normally comes size to minus and reamers will rarely cut less than the nominal size.
[Edited on 26/10/07 by Mansfield]
posted on 26/10/07 at 06:53 PM Reply With Quote
Al
Knew that really , just my sense of humour
[Edited on 26/10/07 by rusty nuts]
Confused but excited.
posted on 26/10/07 at 07:28 PM Reply With Quote
Of course, it all depends on the degree of surface finish of the sliding surfaces. The better the finish the tighter tolerance that you can have, up to a point.
daviep
posted on 26/10/07 at 09:22 PM Reply With Quote
Depending on the length of the parts unless you have a very good machine you will struggle to bore the internal parallel. If I was doing this I would turn the shaft and then ream the hole to suit using an expanding reamer.
What you are describing sounds really easy....until you try to do it. I really struggle to take a 1 thou cut on my lathe at home.
mark chandler
posted on 26/10/07 at 09:28 PM Reply With Quote
I,ll second that, just about fits, just about fits, a wafer to go.... start again.
doh
Wadders
posted on 26/10/07 at 09:45 PM Reply With Quote
LOL Iv'e spent hours turning stuff 'somewhere near' and then seconds making it fit like a wizards sleeve.
One day i will treat my lathe to a DRO
Al.
doh
[Edited on 26/10/07 by Wadders]
New Topic New Reply
