New Topic New Reply
Author: Subject: Petrol Tank, plastic/Aluminium
unkle
posted on 29/11/07 at 07:29 PM Reply With Quote
Whats the main advantages/disadvantages of a plastic tank rather than a aluminium tank?
For I guess it's a lot lighter - any downsidws other than cost?
[Edited on 29/11/07 by unkle]
mookaloid
posted on 29/11/07 at 07:39 PM Reply With Quote
There's quite a history of plastic tanks springing leaks - do a search on here.
I had one - it leaked
scotty g
posted on 29/11/07 at 08:15 PM Reply With Quote
hmmm, i was gonna use a plakky tank, maybe i should have a rethink!
posted on 29/11/07 at 10:47 PM Reply With Quote
With the need to use thicker plastic sheet than ally sheet is there any significant difference in weight, particularly as a % of the weight of the tank + petrol?
twybrow
posted on 29/11/07 at 11:48 PM Reply With Quote
Custom make a GRP tank. That way you can make it exactly the size you want. You would need to use a fuel reistant resin/gel but then, the world is your oyster!
Brooky
posted on 30/11/07 at 08:14 AM Reply With Quote
plastic tanks can work. We use 1800L water tanks at work. When we first started using them they burst quite a lot. Now, a few years down the line, they only burst when we accidentally put a 10bar pressure fed supply into them.
prelude1980
posted on 30/11/07 at 06:37 PM Reply With Quote
we make plastic water and chemical tanks at work, i'm the design engineer, they just need to be designed to take whatever your putting in to them
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
DarrenW
posted on 30/11/07 at 08:14 PM Reply With Quote
My plastic tank has ben fine for 2 years so far.
posted on 30/11/07 at 10:33 PM Reply With Quote
In all fairness, it was one manufacturer off this site who allegedly was given sub-standard solvent. Unfortunately that chap unsubscribed after a large number of tanks started to leak. It has to be said that many of the ones he made didn't leak - but there was always an element of doubt after that.
Plastic tanks have been used in the motor-boat world for decades with no problems - it depends on the standard of construction and the quality of materials.
In my case, I bought an aluminium tank from a reputable supplier (Allyfab) purely for safety's sake. Cost not a lot more, but I was more than happy with the product.
iank
posted on 1/12/07 at 11:44 AM Reply With Quote
Tek tanks can make plastic tanks any size you want, they also do a range of standard ones which I'd expect are much cheaper.
http://www.tek-tanks.com/
Another source is Rally Design who sell American Jaz tanks.
http://www.rallydesign.co.uk/catalog/index.php?cPath=281_303
Finally do a search on "deneo" he's been known to make aluminium tanks for board members.
Anonymous
New Topic New Reply
