Pdlewis
posted on 14/12/07 at 10:45 AM |
Dash blank design software
Not sure this is the right place but here we go:
what is the easiest program to use to design say switch pannels to go on my dash. I already have the carbon these little pannels are going to be made
from i just need something i can make some templates so all the switches/lights are spaced correctly etc all templates will be smaller than a4 so can
be printed.
I have tried autocad but i cant work out how to make it do auto spacing to be honest the problem with autocad was defiantly between the keyboard and
the seat!! any suggesttions?
Paul
Mr Whippy
posted on 14/12/07 at 10:53 AM |
Piece of paper and a pencil, tape it to the dash and be creative.
a ruler is also a good idea
[Edited on 14/12/07 by Mr Whippy]
rayward
posted on 14/12/07 at 11:02 AM |
THIS? ay use
Ray
Mr Whippy
posted on 14/12/07 at 11:13 AM |
quote: Originally posted by rayward
THIS? ay use
Ray
I've seen this before but it will not print out the layout which is a pity
posted on 14/12/07 at 11:14 AM |
yep, the ice cream man is right.
trial fit dash in car and stick on carboard templates of the instruments/switches etc so you can see whcih ones are in line of sight with you sitting
in it and hold steering wheel.
no fancy software is gonna do that for you.
westcost1
posted on 14/12/07 at 11:23 AM |
i just got it to print fine
rallyingden
posted on 14/12/07 at 11:24 AM |
Liker this ?
Just grab it with Ctrl Alt Print screen. Put it in painshop pro, crop & print....
[Edited on 14/12/07 by rallyingden]
posted on 14/12/07 at 11:38 AM |
Sorry, what am I supposed to be looking at? My eyes keep drifting off to the left
rallyingden
posted on 14/12/07 at 11:44 AM |
Does This Help
RD
posted on 14/12/07 at 12:03 PM |
quote: Originally posted by rallyingden
Liker this ?
Why not use the "Print Page" button which you find by clicking the right arrow on the "controls" box all the way to the end of
the options?
Humbug
posted on 14/12/07 at 12:05 PM |
I took photos of my main gauges, printed them out (on normal paper) and stuck them on the dash with bits of masking tape, moved them about until I was
happy, then marked out and drilled/cut the holes.
Pdlewis
posted on 14/12/07 at 12:06 PM |
I was after something less generic i dont want to design my entire dash just a few squares arround 200mm x 100mm which have button evently spaced and
central with bolt holes the same spacing form the corner. It may be easier to use a pencil and graph paper just thought this sort of thing should be
easy on a pc
davidosullivan
posted on 14/12/07 at 12:54 PM |
If anyone you know has a mac you could use OMNIGRAFFLE it has a free trial but you cant use on microbluff windoesnt
Its a simple drawing package but uses "smart guides" that lines everything up.
Although, I have it and I'll be sitting in the car to line mine up
D
Confused but excited.
posted on 14/12/07 at 02:43 PM |
quote: Originally posted by Pdlewis
just thought this sort of thing should be easy on a pc
If you are running XP, can't you just use Visio?
Humbug
posted on 14/12/07 at 04:59 PM |
Does This Help
RD
is this more appropriate?
trextr7monkey
posted on 14/12/07 at 06:01 PM |
Hi Paul ,
Not sure If I'm advising Granny about egg sucking but you can use Excel for drawing
- if you highlight whole sheet then set column width to 1.71 you get a square grid, you can snap things to the grid, copy and paste etc
-if you have the drawing tool bar out as wellas auto shapes it should do whatyou want with no CAD qualification being required
If you make sure it prints the gridlines you will be able to align different bits of your dash easily
HTH
atb
Mike
