New Topic New Reply
Author: Subject: Need a favour...
posted on 15/1/08 at 08:17 PM Reply With Quote
Need a favour...
I need someone with a Weber 32/36 DGV down-draft carb that still has its auto-choke attached to do a bit of measuring please!
Could you tell me the diameter of the inlet and outlet pipes?
cheers,
RichardK
posted on 15/1/08 at 08:39 PM Reply With Quote
The water pipes? Haven't got the carb but when I converted to a manual choke for some reason kept the bits I removed, can do it it the morning mate.
Rich
[Edited on 15/1/08 by RichardK]
Gallery updated 11/01/2011
posted on 15/1/08 at 09:50 PM Reply With Quote
Cheers!
(I thought I'd kept mine, but they're nowhere to be seen...)
RichardK
posted on 15/1/08 at 10:25 PM Reply With Quote
Here you go mate. Both ends the same.
Anything else just U2U
Rich
posted on 15/1/08 at 10:33 PM Reply With Quote
Excellent - cheers!
This solves my problem of trying to locate a pair of 90-degree bends in 16mm rubber hose. There's a short length of pipe that goes from the auto-choke to the inlet manifold - 2 sharp bends with a short straight bit in-between!
RichardK
posted on 15/1/08 at 10:43 PM Reply With Quote
So what happened to the bike carb conversion then?
I've just bought some cbr600 carbs, same as yours so have been following your work.
Rich
posted on 16/1/08 at 08:53 AM Reply With Quote
See my U2U and my web page!
I need two 90-degree bends in 5/16" id rubber tube, and I'm too poor/tight/mean to buy silicone rubber ones. These will form the pipework between the water pump and the inlet manifold spigot when combined with a bit of copper pipe and some solder bends.
If I can get one of these choke water tubes I have the 2 bends I require! (Visiting my local Partco on Saturday morning)
posted on 16/1/08 at 09:49 AM Reply With Quote
dunno if it helps but the rover v8 (P5/6/SD1) has small elongated S-shaped pipes between the inlet manifold and water pump.
there may be enough angle/length for your application; otherwise it is looking trhough the boxes.
it is unlikley the place will stock these parts.
if I remember and if you want, I'll take a look at some old ones I have and photo/dimension for you.
posted on 16/1/08 at 10:38 AM Reply With Quote
I've been regularly amazed at what Partco stock, or can get from another branch within a couple of days.
I've bought single x-flow gaskets that cost a Pound or two, and they're happy to ship them from 50 miles away...
New Topic New Reply
