locoboy
posted on 23/1/08 at 11:49 AM |
diff or half shaft gone?
My mate has a 1991 disco 200tdi and when we were off roading at the weekend he heard a bang and lost drive.
He rolled back down the hill and saw a rock that he thought he had hit (I don’t think he hit it)
When trying to drive again there were all sorts of nasty grating noises.
We towed it back to the yard and later found when the front end was lifted up and drive engaged the front prop would spin but the wheels would not.
When put in Diff lock the car would drive – using the rear wheels.
This points at front diff or broken half shaft doesn’t it?
Is there a way of determining which without things getting messy!
The grating noise has gone now, neither front wheel spins when drive is applied, when one front wheel is turned the other one does not move either.
Locoboy
DarrenW
posted on 23/1/08 at 12:12 PM |
More likely to be the half shaft, its a common fault especially if you use big grippy nobbly tyres. Removing the half shafts seems to be simple enough
so shouldnt take long to diagnose.
You cant rule out the diff at this stage but shaft is more likely.
posted on 23/1/08 at 12:13 PM |
The CV joints on the Disco can fail due to water ingress etc.
posted on 23/1/08 at 12:17 PM |
Shouldn't they make clacking and clicking noises if they're about to fail?? I know the one on my tintop does
TGR-ECOSSE
posted on 23/1/08 at 01:15 PM |
Its more than likely the halfshaft. Its not too big a job to get them out to check. I'v got a spare front axle from my disco if you want. Just
let me know when you will be up to get it
posted on 23/1/08 at 02:57 PM |
a diff's a diff's a diff....
Series LR were prone to busting rear halfshafts but not heard of many breaking the front ones; likewise with defender.
I don't think will be able to tell if its the diff or 0.5 shaft.
If you jack up one ront wheel and turn it - the prop should turn, if not then it is shaft or diff.
Do other side if prop does not turn then it is most lilely to be diff (unlikely to broke two half shafts).
If both wheels trun the prop, it may be central diff but I doubt it.
... and it is more likley to be a CV join going than the shaft itself.
ultimately you are gonna take the front axle part.
DarrenW
posted on 23/1/08 at 03:16 PM |
Front half shafts can and do break. A mate did one recently. Its also hard to tel between failed dff and just the half shaft but all will become
apparant when old shaft is removed.
Mr Whippy
posted on 23/1/08 at 05:10 PM |
also been there...you can get stronger half shafts
adithorp
posted on 23/1/08 at 05:35 PM |
Half shaft!
adrian
