ettore bugatti
posted on 11/2/08 at 09:41 PM |
Nice software to measure power
http://land.heim.at/pampa/252319/tmt/gsf_dyno.html
Excellent!
No fuzz, instant results
What more do you want?
And this is no SPAM!
Ivan
posted on 12/2/08 at 06:54 AM |
Cool software but seems to be only suited to 2-stroke engines.
I would guess that you would have to double the hp obtained for 4-strokes?
And possibly double it again if you have twin exhausts? Then you also double the problems in <50hZ range.
posted on 12/2/08 at 10:23 AM |
What makes you say that? Looks very much like the older HomeDyno program which worked very well if you could find a quiet enough, flat enough and
long enough road!
Ivan
posted on 12/2/08 at 11:15 AM |
long enough road!
I say that because he mentions it on his site and if you go by sound a 2-stroke fires on each revolution whilst a 4-stroke fires every 2nd rev. So
sound frequency will be very different for each type of engine. I don't see a choice of 2 or 4 stroke on his screen shots either so quess
it's written only for 2-stroke.
gingerprince
posted on 12/2/08 at 01:29 PM |
From the description of the parameters you can set: -
Dynamo/Mic Signals per Rotation: If you recorded the dynamo/alternator (or microphone), type in its amount waves per motor rotation. If you
don't know it try some numbers until you get the right RPM range. For the microphone recordings: 2Stroke 1Cylinder: 1, 2Stroke 4Cylinder: 4,
4Stroke 4Cylinders: 2.
This will allow you to tune to whatever engine you have.
ettore bugatti
posted on 19/2/08 at 12:27 AM |
I even tried with an 1.4TDI 3 cylinder equipped car and even that worked out. (dynamo/mic signals per rotation: 4Stroke 3Cylinder:1,5)
For a low powered car you only need 200m to reach 20kmh till 70kmh (or full range of second gear) so that is not really the problem.
Ofcourse you shouldn't turn your radio on, but otherwise it is quite unsensistive for noise.
I did record sounds with my ear plugs as microphones and even then the program was able to turn out a realistic power curves.
G-tech pro, eat your heart out!
Dangle_kt
posted on 19/2/08 at 11:22 AM |
Half it surley?
