macspeedy
posted on 23/2/08 at 05:42 PM |
Aluminium bargin?
Went to a local stockist of metal today won't mention any names, anyway got a real bargin 3mm aluminium sheet 1400x800mm and a small piece of
checker plate for £20 things is the aluminium has laser cut film on it, what type of aluminium does this make it? and how much of a bargin did i get?
dave1888
posted on 23/2/08 at 06:07 PM |
Did you get a receipt for it.
macspeedy
posted on 23/2/08 at 06:12 PM |
cash sale
Bluemoon
posted on 23/2/08 at 06:21 PM |
So long as it's not some strange aircraft grade that needs to be stored cold else it hardens, yes sounds good... (You will find out if you try
and bend it)..
Dan
skodaman
posted on 23/2/08 at 07:54 PM |
'Did you get a receipt for it.'
Yes without a receipt u can't use it cos of sva. I'll give u a tenner for it.
Skodaman
mark chandler
posted on 23/2/08 at 08:22 PM |
Thats not a big sheet, 1200x800, just an offcut from a 4800x2400 sheet which would be around £60 from memory.
You just got scrap value + a bit I recon
nasty-bob
posted on 23/2/08 at 08:24 PM |
I think the film is to minimise the reflection if the sheet is to be laser cut. This film does not mean that the ally itself is a special grade for
laser cutting.
As for it being a special aircraft grade, this is unlikely as laser cut aluminium cannot be used on aircraft due to the affect on material properties
around the cut (laser being a hot process).
donut
posted on 23/2/08 at 09:12 PM |
I thought the film was to stop it scratching???
macspeedy
posted on 23/2/08 at 09:19 PM |
£60 would get you a sheet of normal 1.5 mm i would recon.
Fred W B
posted on 24/2/08 at 09:43 AM |
Pull some off the plastic off, the grade should be marked on the plate.
The plastic being on does not mean anything, any material can be ordered ex mill with it. As Donut says, it's applied to protect the surface.
Fred W B
[Edited on 24/2/08 by Fred W B]
