kilvil
posted on 24/2/08 at 04:10 PM |
balsa wood supplies
Looking for recommended sites to purchase balsa wood sticks to test new chassis designs. looking for 1/8th by 1/8th square lenths. Also which glue is
best to use.
kilvil
meany
posted on 24/2/08 at 04:14 PM |
find a model shop near you.
buy some there..chances of getting them un broke through the post...remote.
you could get 1/8th sheet, 3 or 4 inch wide and cut your own .
where abouts are you, i have loads.
donut
Search for model shops. You must have a local model shop near you or look on the net. I know of a really good one but can't remember the
name!
PVA white wood glue is good. Cyno for instant stick but be quick!! or 5 / 10 minute epoxy for super strong fix.
meany
posted on 24/2/08 at 04:19 PM |
my local one is this.
http://www.blackburnmodels.com
iank
posted on 24/2/08 at 04:44 PM |
If you have a hobbycraft near you they sell it.
http://www.hobbycraft.co.uk/
I use a small hot melt glue gun - be careful though it hurts on skin
Anonymous
meany
posted on 24/2/08 at 04:48 PM |
oh yeah, forgot to mention.
i would use a thin or medium thickness cyano.
zetec
posted on 24/2/08 at 04:51 PM |
Would suggest hardwood for the roll cage, RAC spec.
907
posted on 24/2/08 at 05:01 PM |
Medium thick super glue.
Not gel, or the stuff like water.
Paul G
kilvil
Forgot to mention living in wiltshire, will have a look into bath seam to remember there is a model shop there, if not will order from hobbycraft
online. thanks for your help.
kilvil
Confused but excited.
posted on 24/2/08 at 05:09 PM |
If you treat the outside of balsa wood with a thin coat of cyano, it becomes suprisingly strong.
indykid
posted on 24/2/08 at 05:35 PM |
isn't the purpose of this exercise to use balsa, untreated, because it's mechnical properties are like that of scaled down steel?
tom
Mr Whippy
posted on 24/2/08 at 06:03 PM |
black burn models is my supplier, used them for years good crowd.
tomblyth
posted on 24/2/08 at 08:13 PM |
use D4 adhesive as pva to flexible and cnyo is to brittle
