smart51
posted on 27/3/08 at 06:32 PM |
can you weld to handbrake cable?
An odd question, yes. I must have clicked on the wrong thing and rather than buy solder on cable nipples, I bought extra ferrules. My fault.
Anyway, what other ways can I fit ends to my cable. All suggestions are welcome but why not drill through a piece of round bar and weld the other end
of the brake cable? Or is that just stupid?
madteg
posted on 27/3/08 at 06:36 PM |
I have put a blob of weld on the end of my cable, its lasted 18 months up to now but you have to be very quick as it melts so easy. kev.
MikeR
posted on 27/3/08 at 06:42 PM |
i've heard of people splaying the ends of the cable once they've got something on and then putting a blob of weld on the splayed ends to
stop the thing slipping past.
posted on 27/3/08 at 07:07 PM |
I found a blob of weld tends into a neat ball on the end of the cable --
paulf
posted on 27/3/08 at 07:30 PM |
I welded a steel nipple onto mine, its lasted 4 years so far.Just countersink the end and then fit the cable, splay the end apart then weld it quickly
using a highish current so that it fuses into a blob.May be worth practicing on a scrap bit of cable first.
Paul.
russbost
posted on 27/3/08 at 07:34 PM |
Surely brazing would be better?
posted on 27/3/08 at 07:53 PM |
Yes
snapper
posted on 27/3/08 at 08:00 PM |
Brazing cable is just as difficult, the heat to melt the brazeing rod would melt the individual fibres of the cable.
You could heat the ferul and add braze.
I used a small bolt drilled through and the weld method.
Also smaked the bolt to crimp it to the cable as well
I eat to survive
I drink to forget
paulf
posted on 27/3/08 at 08:21 PM |
I have brazed cables in the past but it is difficult to do without softening the cable beyond the nipple, leading to it fraying.if done with care and
a little practice it is possible to just fuse the ends of the cable with no heat transfer to the rest.
Paul.
nitram38
posted on 27/3/08 at 09:01 PM |
I haven't done this on a handbrake cable but silver solder and a fine flame on it will be better.
westf27
posted on 27/3/08 at 09:16 PM |
I welded my niples or is it nipples? well there were two anyway
smart51
posted on 27/3/08 at 09:45 PM |
Welding the cable is the quickest way of cutting it I've ever found It even leaves the end cortorised. Passing it through a drilled hole
takes away the heat enough to weld to it nicely. In the end, I thought of a good way to bolt the cable so don't need to weld after all, except
to stop the ends fraying.
RazMan
posted on 27/3/08 at 10:52 PM |
Silver solder and a micro flame torch works for me
Raz
